Lumintop GT3 - Questions
16 posts / 0 new
Artiet59
Last seen: 3 hours 48 min ago
Sorry, don’t know if i should start a new topic for asking questions about lights that I cannot find reviews or comments about when searching the BLF search thread. So if i am out of place, please let me know.
Does anyone have the Lumintop GT3?
3 x XHP70.2 leds
4 × 18650’s
looks like its anywhere from $93-$129 depending where your shopping..
Anyone own it?
what are your likes or dislikes?
Does it have a buck or boost driver?
obviously we’re not buying this light for perfect tint and color, but definitely output and smile factor.
Please let me know!
-Art
MoreLumens
MoreLumens's picture
Last seen: 8 hours 38 min ago
I almost got it. Well actually ordered it from BG, but canceled it.
Not sure why, it seems like a nice light, but would love to see beamshots and runtimes first.
I wonder are those 6V or 12V leds? Just thinking if GT-FC40’s would work.
Artiet59
I was wondering the same thing about the leds, abd if the ones Simon has now would work!
Also, there is a YouTube video review, it’s really good, it’s just in Chinese so I don’t understand it. But the beamshots look awesome.
Also- the video review says the “updated specs from lumintop” say the throw is 725 meters. The specs on neals gadgets says 585 meters or something like that. Limintop website says 725 meters.
I’m wondering if anyone knows- did they change something with the GT3 to give it more throw between now and the release date? I don’t feel it’s been out that long.
Artiet59
Good video review with outdoor beam shots at ending
https://youtu.be/SYyzF0TmeiA
Sirstinky
Last seen: 2 hours 16 min ago
Those are most likely 6v xhp70.2 behind a 2S2P battery arrangement.
MoreLumens
Oh review and everything else:
https://1lumen.com/review/lumintop-gt3/
Also:
“the new batch of Lumintop GT3 flashlights will use Anduril firmware instead of NarsilM.”
“So you can see that after 5 minutes both Turbo and High (top of ramp) drop to below 2000 lumens. Turbo drops to roughly 1060 lumens after 17.5 minutes, and High does the same but at 23.5 minutes.”
It’s not bad. Kinda want.
Artiet59
Yea me too. But I don’t own a d18, or mf01s so I’m torn, even the thrunite tn36 limited looks cool too.. the reflectors on the gt3 look sweet though. And turbo actually hits 15k at 30 second,awesome
Sunnysunsun
Sunnysunsun's picture
Last seen: 3 min 7 sec ago
What’s not to like? Between my D18 and this for a hundred bucks, I’d pick this. That said, these popcan lights are really cumbersome relative to single battery lights and I frequently find myself not wanting to carry the D18 because it’s simply too heavy and my 3X xhp50.2 lights have pretty much the same perceived output.
Scallywag
Scallywag's picture
Last seen: 5 hours 54 min ago
Also:
I’m really surprised by those numbers. My Supfire M6 just has 50.2s (3V) and it will hold 6A solidly until the batteries drain. Shouldn’t this be able to sustain higher?
Old Lumens Contest 2020 - Hand-made light category
ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20 | Baton S1
Boruit D10 w/ Quadrupel Fet+1/Anduril | EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Olight S15 Ti | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special | Thrunite T10Tv2
Supfire M6 3xXHP50.2, Sofirn C8F, Unfinished: Sofirn SP70, IYP07/Tool AAA hot-rods, Jetbeam E3S
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
MoreLumens
I really don’t know, but because stepdown is temperature controlled and new versions have Anduril, you probably could adjust it?
Artiet59
Thanks for this feedback, I appreciate it,
Scallywag
Scallywag's picture
If the light gets too hot to hold then there’s something strange with the thermal path, though.
MoreLumens
Was there any review that said GT3 gets too hot, did I miss something? Maybe stepdown is just adjusted too low or ambient temperature setting is off?
Not sure how that temperature stepdown works in that review sample which had NarsilM, but still those numbers seems a bit low for that size of light. I mean H30 can hold a steady 1000 lumens.
Scallywag
Scallywag's picture
Sorry, I’m making some assumptions. Thermal configurations can be adjusted, but if you turn them up high enough eventually the light is unusable anyway because you can’t hold it.
My M6 gets uncomfortable, but not painful, after long durations (over half an hour) at 6A. With NarsilM/Anduril on the GT3, thermal configurations could still be turned up, but would it sustain 2000+ lumens without becoming too hot to hold? Depends a lot on the physical thermal path. If the shelf is thin, there won’t be much to do.
mortuus
mortuus's picture
Last seen: 18 hours 47 min ago
It cant keep up turbo for very long or ? that much lumens drop fast and i bet it will get very hot just after minute or two..
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
MoreLumens
Well after searching I found one reddit thread that said it will get hot in about 45 secs turbo which kinda sounds like normal for that output?
