[Review] Wuben E6 || 14500 / AA - OSRAM CSLPM1.TG || An ultra compact EDC thrower || 10% Coupon Code
46 posts / 0 new
bilakos10
bilakos10's picture
Last seen: 10 hours 20 min ago
The Wuben E6 was sent to me by Wuben for evaluation.
Coupon Code (-10%): CD10E6FH
The E6 is a compact little thrower that runs on an 14500 cell.
It's e-switch operated and comes with a matte black finish.
Its switch is surrounded by a metal ring and is backlit.
The flashlight comes with a lightly crenelated bezel which protects the glass lens.
The head of the E6 houses a smooth reflector along with an OSRAM CSLPM1.TG
Thanks to a centering ring, the emitter is perfectly centered.
The head can be easily taken apart, since the threads are not glued.
As you can see, Wuben has followed a very interesting design for the head's internal components.
The OSRAM  CSLPM1.TG sits in a small PCB in the center of the head, while the driver board is hollow in the middle and wraps around the emitter PCB.
Such design allows Wuben to produce a very compact flashlight with a quite deep reflector.
The rear of the E6 is flat, which allows the flashlight to tailstand.
The side flaps are drilled in order to be able to accommodate a lanyard.
As can be seen, the head and body are constructed from a single piece of aluminum.
The tail threads are very smooth and are anodized.
The tail houses the copper spring along with its board.
Wuben has used a brass tab as the positive terminal, in order to decrease the overall resistance.
Of course, being an EDC light, the E6 comes with a pocket clip.
The pocket clip is very strong and robust.
It's held into place with two torx screws
The E6 is powered by either an 14500 or an AA battery.
As usual, the manufacturer has included a Wuben branded 14500 cell that's capable of 920mAh of capacity.
I actually did two full charge/recharge cycles and its rating seems accurate.
Here's a photo demonstrating the size of the Wuben E6.
From left to right:
Skilhunt M150, Wuben E6, Lumintop Tool AA, Sofirn SP10b, Convoy S2+
User Interface
Note: As already stated, the E6 is a pre-production model. Its final firmware might differ from my sample.
Here's all the actions supported from the flashlight's UI.
Turn on/off: Single press.
Mode cycle: Long press ( Low > Mid > High > Low > ... )
Strobe: Double press.
SOS: Double press while in Strobe.
Enable / Disable e-switch backlight: Triple press while off.
Lock / Unlock: Quadruple press while off.
Output
Here's the output measurements I recorded, along with the respective current draw.
As can be seen, the E6 pushes 972 lumen at High, which is very impressive for such a compact flashlight.
What's more impressive is its beam throw capabilities (beamshots coming tomorrow laughing)
Things I liked
 - Excellent build quality.
 - Very compact design.
 - Uses the OSRAM KW  CSLPM1.TG  emitter, which is an excellent choice for producing a nice long beam.
 - Its performance and beam throw distance is very impressive for its size.
 - Very lightweight.
 - The pocket clip is great.
A few improvements I would like to see.
User-Interface suggested improvements
- Add an even lower brightness mode (Moonlight).
- Strobe mode should be accessible via Triple click (not Double click).
- Allow quick access to Low (via Long-press while off) and Turbo (via Double click).
Design suggested improvements:
While testing the E6, I noticed that some batteries wouldn't fit in it due to their length.
After a few measurements, I found out that the E6 will only accept 14500 cells that are max 51mm in length.
I think that's quite a problem, as a lot of 14500 celss are 52-53mm in length.
Just as a reference, here's a picture comparing Wuben-branded battery (it's the blue one, on the left) that arrived with the Wuben E6 with some other 14500 cells that I have.
Beamshots
Here's some outdoor beamshots.
Overall I think the Wuben E6 will turn into a very popular flashlight.
What do you think about it?
Edited by: bilakos10 on 04/30/2021 - 14:55
MoreLumens
MoreLumens's picture
Last seen: 10 hours 26 min ago
Looks nice. Just might get one if the price is right. Vapcell L10 should fit, not sure about H10 which is a button top.
Is there memory in UI? Maybe medium mode should be a little more? Seems kinda weird spacing.
Scallywag
Scallywag's picture
Last seen: 1 hour 58 min ago
Looks like fun. Would love to see them take this approach on a tube light rather than a thrower – could make for a nice compact EDC and some zebralight competition.
bilakos, I’d love to see the light pictured next to other common lights (maybe Tool AA and Convoy S2+ if you have them?) for a good size reference.
gchart
gchart's picture
Last seen: 1 hour 16 min ago
Really interesting / cool how they did the driver. Unibody, too… nice.
bilakos10
bilakos10's picture
Scallywag wrote:
Looks like fun. Would love to see them take this approach on a tube light rather than a thrower - could make for a nice compact EDC and some zebralight competition. bilakos, I'd love to see the light pictured next to other common lights (maybe Tool AA and Convoy S2+ if you have them?) for a good size reference.
That's a great idea smile
From left to right:
I think the photo demonstrates how compact the Wuben E6 really is!
gchart
gchart's picture
Wow. So shorter than a Tool AA and head is a little wider than an S2+?
MoreLumens
Looks like GT Micro has been challenged. Still hard to beat that ramping UI, but on the other hand, max mode is pretty much only one that I even use. Maybe a bit mediumish too. I wonder which one throws better?
buck91
buck91's picture
Last seen: 3 hours 58 min ago
I said I was done purchasing new lights for a while… I don’t suppose this supports lower voltage chemistries (with reduced performance) as a backup to the 14500?
bilakos10
bilakos10's picture
It does run on AAs as well!
Today I was short on time and couldn’t thoroughly test everything, but tomorrow I’ll make sure to update the thread with some AA measurements.
buck91
buck91's picture
Ah crap, thats wonderful. Any idea on when they will be available?
bilakos10
bilakos10's picture
Yes, there’s mode memory in place.
As for the spacing, I agree. Visually the modes are OK, but I wouldn’t say no to a more refined mode spacing. For example, I think something like this would work nicely:
UltraLow: 1 lm
Low: 15 lm
Medium: 130 lm
High: 450 lm
Turbo: 900+ lm
MoreLumens
I wouldn’t even need those lowest modes with that. M-H-T would be good for me.
Nice to hear that there is memory. That’s important in thrower.
Starts to look like a must buy if price is something maybe under 30€.
pc_light
pc_light's picture
Last seen: 1 week 4 hours ago
Nice review Bilakos10. Thumbs Up
I’m always excited by new AA/14500 offerings and this one looked appealing …but then it occured to me that aside from the OSRAM it might be very similar to another light already in my collection. Although it would be fun to compare the XP-L Hi to the CSLPM1.TG’s performance.
(Sorry, I couldn’t resist some fun with a visual comparison, it’s a Friday.) Wink
bilakos10 wrote:
Seeking the light.
id30209
id30209's picture
Last seen: 8 hours 41 min ago
I like this one.
I would complain only  (at this time) about the clip. Cannot rid of the thought it's poorly designed.
It should be deep pocket carry and not partial as it is now. By deep carry I mean only one radius and NOT 2way like on FW3A and Olights...
WTB Titanium 4sevens 2xAA tube
Agro
Agro's picture
Last seen: 2 min 21 sec ago
Is it unibody?
Could you tell more about how did they connect the positive pole to the driver?
JaredM
JaredM's picture
Last seen: 1 hour 34 min ago
It is unibody, and I was hoping Bilakos could take another picture of the driver showing the whole thing. Very curious about the topology myself..
darosk
darosk's picture
Last seen: 1 day 6 hours ago
Curious minds want to know the price.
My Lights (Updated: Feb 5, 2021)
Artiet59
Last seen: 6 hours 19 min ago
Yes price and availability please?!
bilakos10
bilakos10's picture
Agro wrote:
Is it unibody? Could you tell more about how did they connect the positive pole to the driver?
It is indeed unibody!
It's plausible that the driver is double sided, with its rear side also housing the brass tab (positive terminal), which goes through the drilled base.
Here's a few close-up pictures of the driver and its back side.
MoreLumens
Beamshots maybe soon? Blushing
bilakos10
bilakos10's picture
MoreLumens wrote:
Beamshots maybe soon? :BLUSH:
I know I promised that I would be publishing some beamshots this weekend, but unfortunately the area I live in went into lock-down due to Corona, so we're only allowed to stay outside of our homes up until 6.00pm frown
I think the lock-down restrictions will be raised to 9.00pm from tomorrow onwards, so if that's the case, then I'll definitely be grabbing some outdoor beamshots pretty soon!
jim48
Last seen: 2 days 16 hours ago
A tail magnet would be Practical maybe.
bilakos10
bilakos10's picture
captainkirk
Last seen: 6 hours 50 min ago
Nice beamshots, any idea of the distances?
Thanks
This space for let.
Agro
Agro's picture
It’s plausible that the driver is double sided, with its rear side also housing the brass tab (positive terminal), which goes through the drilled base.
This is not simple…the brass tab and its electrical path must pass be insulated from the shelf…and it would be interesting to know how.
buck91
buck91's picture
Since this thread hasn’t seen much activity in the past month figured I would check in. Has anybody heard any release info yet?
bilakos10
bilakos10's picture
I’ve just sent an email to my contact at Wuben.
As soon as I hear anything back, I will let you know Big Smile
Lightbringer
Lightbringer's picture
Last seen: 3 hours 35 min ago
Yeah, the UI definitely needs work. 2click for strobe is pretty hideous.
Moonlight would be nice, if not a must (at least for EDC).
Even if not an “EDC” light, I mostly use my GTmicro in basically only 2 modes, moonlight (reset down to 1 from the default 3/5/whatever) and wide-open. Even low is “too high” when I just want to see the clock across the room, etc.
Backlit switch only if constant, not “breathing”. That’s one dealbreaker for me. F’n creepy…
dts71
Last seen: 3 weeks 17 hours ago
How long can it maintain high mode?
Will it step down by timer or by temperature?
How many lumens will it step down to?
bilakos10
bilakos10's picture
Ok, just got a response from Wuben.
The E6 should become available at late April !!!
Kos70
Last seen: 8 min 50 sec ago
