I’d like to built some lamps from LED strips around my home. The most important thing would be High CRI / low blue and very nice “area” light, not point like from a single lamp.
I am planning to buy Auxmer 2835 2400K light, but I’m not sure in a couple of details:
For the PSU I decided I’ll just buy a Meanwell. I’m confused about range though: there are LED specific models, like LPV-35-24 and the normal range like LRS-35-24, GS25E24, GST25E24-P1J or GST40A24-P1J.
Now for dimming I’m trying to understand the different option.
Option 1: don’t dimm. I’d buy 4.8W/m strips and put 2 next to each other, so I can have 4.8 vs. 9.6 Watts. I like that it’s simple and guaranteed flicker free.
Option 2: I’d need a very high kHz dimmer to make sure it’s flicker free and also hopefully over the audible range, so 25 kHz+. I’m confused here, I don’t want anything smart or wireless, but the only one I found are: QuinLED-Quad - I’d need SMD soldering for this, which I have never done Waveform FilmGrade™ Flicker-Free LED Dimmer - I’m not going to spend $79 on a LED dimmer for a single lamp.
If you want just rough dimming you can supply lower voltage to LED strip, it will dim. No need for PWM. Vf of LEDs will limit current.
LED strip is just LEDs in series with resistor. 3 + resistor for 12V strip and 6 + resistor for 24V (simple strips at least), repeated as many times as needed.
So what is wrong with supplying less than specified voltage to a LED? For example if I supply a 24V LED strip with 18…24V? I’ve read something here like that the color / CRI change compared to the same luminosity with PWM?
Also, if I understand correctly this is how the CCCV LED PSUs work from Meanwell, isn’t it? When you set the current it actually supplies less voltage right?
This can be dimmed with a simple pot and it adjusts the CC part. So if I understand it right, this works for most LED applications but it’s not good for High CRI because color changes in the CC / under-voltage part?
