[Interest Check] Wurkkos TS30A / TS30G - red or green pocket thrower
6 posts / 0 new
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 2 hours 34 min ago
Hello everyone,
Wurkkos would like to know if you are interested in following new concepts, based upon the successful TS30S design. Please feel free to comment.
Model TS30A TS30G
Size tba
Weight tba
Emitter Osram Ostar Projection Power LE A P0MQ amber (614nm) Osram Ostar Projection Power LE CG P0AQ green
Driver 7.5A constant current buck driver
User Interface preferred by manufacturer: Wurkkos proprietary UI (known from FC11 or TS30)
Reflector Single SMO reflector
Max. Output approx. 750lm approx. 2200lm
Max. Beam Distance 579m tba
Peak Intensity  83750cd tba
Power Options 1x 21700 or 1x 18650 Li-Ion battery (with an appropriate adapter sleeve)
Charging USB-C port, input DC 5V 2A
Prototype pictures
Edited by: Lux-Perpetua on 04/03/2021 - 07:22
Lux-Perpetua
[reserved]
Th558
Th558's picture
Last seen: 2 hours 11 min ago
Depends on the throw and price.
maxchaos92
Last seen: 1 hour 30 min ago
Mmm Red one seems to have a good throw,in this kind of light for me ui isn’t a problem, i’m more concerned about having a good enough regulation with temperature control.
Lux-Perpetua
maxchaos92 wrote:
Mmm Red one seems to have a good throw,in this kind of light for me ui isn't a problem, i'm more concerned about having a good enough regulation with temperature control.
Wurkkos will be sending me two prototypes to do some testing and analyzing on runtimes and thermal regulation.
BOMBAY
Last seen: 4 hours 1 min ago
interested depending on price and specifications
