So I am fairly new to this hobby of modifying flashlights, but I don't really do anything halfway. I made a few UF-T20s burned a handful of emitters and a driver and switch or two along the way. Made a S2+ with one if those nice samsung high cri emitters and started working on my newest projects, the UF-1504 & 1405.
For these two I was originally wanting to take the qlite drivers from mtn and add some (4) more 7135s to each so my high mode would be 4.5 amps or so. My once non existent soldering skills had improved a pot since I first started and I had just upgraded to the Hakko 888d so I figured if I needed 2 drivers I better buy 4, and if I needed 8 7135s I better buy 20. I'm currently on board 3 with 4 chips added, 2 remaining and what do you know, it works. It turns on allows you to set mode groups and looks fairly... standard.
I put a plain board and emitter (osram CSLNM1.TG) in a pill for these lights when I first got them to compare t20 to 1504 apples to apples. And this looked the same after all my effort.
So I tried to test the amperage at the tailcap and while I know it is said here this won't be accurate, I also pulled the tailcap off the T20 to compare. Both read 2.4a it's disappointing because I expected the modded driver would read 50% higher even if it didn't read 4.5 it should have read 3.6.
I don't have a clamp meter, but my DMM is a Fluke77 IV so it's not junk, to measure amperage I extended the probes all the way out and shoved them into short pieces of 12ga ofc speaker wire.
So here is my dilemma, I want these flashlights working as one is for a friend of mine. I am going to put in an order somewhere soon for some other emitters and more drivers as well as more 7135s. I will eventually get this skill down, but I am wondering if there is a place I can order a board with added chips at the same time I am ordering the parts to DIY it? Also is there anywhere other than mouser and digikey where I can find the 2mm flat white and/or the other more robust version of the 1mm flat white? I forget the model now and would have to go reread the massive osram post for the hundredth time.
As for the 1405, which is a double 26650 light, I am making an adapter that will allow me to run 18650s because I already have a ton of them, but It's going to parallel them instead of run them in series so I can run 3v LEDs. I would however like to know where I can find extra pills for these lights so I can make a 6v version and a 3v version, as well as make a 660nm pill for night hunting and such. As much as I have looked and read, there isn't much talk of 6v leds which is understandable, but can anyone point me in the direction of the best thrower leds in 6v, or most efficient. I'm much more into seeing well and havi g decent run times, not trying to melt down a flashlight and burn my hand with a light that sucks batteries dry in 15 minutes. Though I wouldn't mind making a separate pill just for that in order to show off a bit sometimes.
I also purchased a SOIC 8 clip and usb avr reprogramming board in order to modify existing firmware and flash my own perfect modes on my flash lights. I haven't started this part of the project yet but like I said, I tend not to do things halfway. I am sure I will have questions but most of them I can probably find the answers to in that huge post where the repository is linked. That's an incredible resource and even though I haven't used it yet I am already grateful the information is out there and organized.
Last but not least, I have been trying to add an internal optic, I believe it would be a secondary optic but I may have my terms mixed up. Basically I just want to collimate the light at the emitter into a spot beam aimed at the back of the aspheric lens on these lights so it isn't wasting half of the available lumens. I ordered a few narrow spot lenses LEDil brand but they have these rings in them and loom aweful. I pulled apart these junky bell howell tac lights and put their plastic aspheric lens inside the head of one of these and it seems to do what I want but is terrible quality. Does someone make a small (16mm max would prefer small enough to fit between the wires on a 16mm mcpcb) aspheric lens preferably with some sort of holder already attached that can be modified to fit if it doesn't already? I can modify much easier than I can fabricate but push co e to shove I can fabricate too.
If anyone has advice or information on any of these topics I would be grateful for it. Also want to say thanks to everyone who contributes here for not only opening my eyes to the possibilities of this hobby but for taking so much time to keep the learning curve from becoming too steep. You guys take a complex hobby with some fairly advanced science and math behind it and break it down in a way that reaches and encourages people to take a shot. Thanks for that, sincerely.
