What high drain 26650 for the Astrolux EA01s?
17 posts / 0 new
Pilotboy
Pilotboy's picture
Last seen: 10 hours 53 min ago
I have an Astrolux EA01s in the mail right now, and I’m not to sure which 26650 to buy. I would prefer a more powerful battery over a high capacity one.
Any help would be much appreciated.
zoulas
zoulas's picture
Last seen: 1 hour 34 min ago
Check Orbtronic.
lionheart_2281
lionheart_2281's picture
Last seen: 12 hours 45 min ago
The Shockli used to be good
Pilotboy
Pilotboy's picture
used to be?
pirate joe 22
Last seen: 6 hours 57 min ago
Who are the primary manufacturers of 26650 batteries ?
I bet if molicell makes 26650s in Taiwan, they would be good.
lionheart_2281
used to be?
I’m not sure, I don’t do such a good job of keeping up with which cells are good and which aren’t
makapuu
Last seen: 2 days 4 hours ago
Golisi, iJoy, or Aspire
If you can get on Facebook, look up the guy Mooch, he tests all kinds of battery sizes.
The vape guys practically consider him God.
You cannot go wrong with any of the 3 I mentioned. I use Golisi.
Pilotboy
Pilotboy's picture
Thanks man. How many amps do you think the EA01s draws?
makapuu
Pilotboy wrote:
makapuu wrote:
Golisi, iJoy, or Aspire If you can get on Facebook, look up the guy Mooch, he tests all kinds of battery sizes. The vape guys practically consider him God. You cannot go wrong with any of the 3 I mentioned. I use Golisi.
Not sure, but if you went for the XHP-50.2 LED’s it’s going to draw more than the SST-40’s
That light can also take 21700’s.
The widely regarded high drain top dog for that battery size is the Samsung 30T
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 5 hours 35 min ago
Golisi S43 (gold)
Keeppower 6000mAh unprotected (PLB-55A cell)
Shockli 5500mAh (PLB-55A cell)
Vapcell 26650 5500mAh 20A red (PLB-55A cell)
Vapcell K64 (unfortunately, out of stock now but coming back)
cclight
Last seen: 16 hours 59 min ago
Depends on the leds. I use 30T with XHP50.2 for maximum current, this flashlight is among the ones that can take highest currents. If you really want 26650 use the Golisi 4300 gold; HKJ tests show it is the best for high currents (except maybe for the K64 but this is not available now).
pennzy
pennzy's picture
Last seen: 5 min 11 sec ago
I am not sure if the G53 is enough battery for you but it got good reviews
https://www.illumn.com/26650-vapcell-inr26650-g53-5300mah-20a-high-disch...
Pilotboy
Pilotboy's picture
So if you had a choice between a 30T and the Golisi gold, which one would you choose?
pennzy
pennzy's picture
Personally I would go for longer run time. The heat build up is so quick that a few extra lumens is short lived any way.
Pilotboy
Pilotboy's picture
Thanks! So I guess the big question is how many amps do I need in a battery? Is 20A enough? Or should I go for the full fat 32A?
pennzy
pennzy's picture
Here you can compare between the Shockli and the 30T
https://lygte-info.dk/review/batteries2012/Common26650comparator.php
cclight
Normally I use the 30T. It discharges fast but it’s not a problem for me. I even have a spare one in the same pocket, just in case. However now that I’m in the “coronajail” I don’t need turbo, so I use a 26650; it doesn’t even need to be the Golisi, I use an Efest and only charge to 4.15V instead of 4.2V…
