Luminus SBT 90.2 cooling
16 posts / 0 new
robart
Last seen: 3 weeks 1 day ago
Hello,
I was wondering what would be the best cooling for a Luminus SBT 90.2? I know that the NH-D15 is a good one but i prefer a round shaped one with the led on top, for building reasons.
CNCman
CNCman's picture
Last seen: 21 hours 37 min ago
May I ask what you are building ?
robart
A strong spotlight.
Yokiamy
Yokiamy's picture
Last seen: 9 min 3 sec ago
NH D15 seems to be a CPU cooler, as Tom said what are you building?
It all depends on what you are looking after, the SBT90.2 actually isnt very great in efficiency, but it throws great.
Cooling is an interesting matter, since there is an optimal working point like in fluid dynamics with heat transfer.
So you are looking for the optimall mass, and finning (surface) combination.
Sirstinky
Last seen: 6 min 43 sec ago
I use old Intel CPU coolers, the round stock ones that came with high performance Core2Duo or Core2Quad processors with LGA 775 or 1366 socket. #1
#2
They are cheap, abundant and work great for up to 130 watts, and are relatively compact (about 96mm in diameter and up to 2.7 inches tall). Plus you have a lot of flexibility with mounting fans of various sizes to them.
You can always use a better quality one, but for the form factor these are great. Zalman also makes good ones in this configuration, and so does Cooler Master and Sythe, but they are much more expensive.
zoulas
zoulas's picture
Last seen: 12 min 4 sec ago
If you are going that route just use the corsair liquid cooling system.
Robin Dobbie
Last seen: 28 min ago
Maybe something like a pin fin heatsink? Mouser has em. Wakefield vette 13080 is like $30 plus US shipping. You can find 133mm pin fin jobbers on ebay for 25-ish shipped from china. They don’t come with a fan, and a fan is probably a good idea.
A gammaxx 400 heatpipe cooler isn’t as… uh, “round” but it comes with a fan, it’s $20 shipped on amazon, and will likely be lighter and quieter than something smaller with a fan. You can replace its 120mm fan with a 120mm IP67 Noctua fan for another 25 bucks for reliability in any weather, up to dropping it in the lake(if its off). Not sure how well the motor would survive trying to propel water.
Agro
Agro's picture
Last seen: 1 min 34 sec ago
Best? I think phase change cooling would be the best but bulky, loud and expensive.
Hank33
Hank33's picture
Last seen: 14 hours 49 min ago
Plus maybe some ice packs?laughing
robart
Thanks for the responding. The pinfin heatsink might be a good option since the light is moving and hold in different positions it would be good for air flow. Will def check that one out!
I think my question with ‘ best cooling’ was not the right terminology haha. Let’s replace that word with ‘suitable’ maybe? I want to try to get the most out of this led. So combining the pinfin heatsink and a ventilator would do…
Enderman
Enderman's picture
Last seen: 3 days 11 hours ago
The NH D15 is one of the best air coolers however you do need a fan to blow air through it, it will not work well passively.
Robin Dobbie
An option, if something gargantuan is acceptable, is the Raijintek Tisis, if you can get it without the fans. In the US it’s possible, and at a significant discount. Then you can add your own IP67 fan(s).
Noctua’s working on a passive cooler, but it keeps getting delayed.
CNCman
CNCman's picture
Water cooling has better cooling but you will need to build it yourself.
Yokiamy
Yokiamy's picture
When current and dimensions are no issue, what about peltier cooling?
sp5it
sp5it's picture
Last seen: 2 hours 41 min ago
There is more heat from peltier to disspate than from the led. Also peltier is power hungry device.
Think of how stupid the average person is, and realize half of them are stupider than that. George Carlin
 Anyone offended by my signature please fill Complaint Form. Thank you.
 If a lot of people listen to Slayer, the world would be a better place to live" - Tommy Wiseau
robart
Power hungry doesn’t matter since i don’t use batteries. I will look into the peltier cooling, never heard of it.
