what mains plug powers this ?
6 posts / 0 new
malkoff junkie
malkoff junkie's picture
Last seen: 9 hours 55 min ago
hi there what mains plug charger works with the LITOKALA PD4 4 bay charger please?
I have a 5A and a 13A and got them mixed up, now I am not sure which one came with that charger.
thanks.
Malkoff !
gravelmonkey
Last seen: 6 hours 49 min ago
Are you talking about just a plug cable or power supply (like a laptop has)…?
Voltage should be marked on the back of the charger. If the two power supplies are the same voltage, I’d use the higher amp one…
If you’re just asking about a plug cable – use the 5A one, no way the charger should draw 13A at 230V – that’s enough to run a vaccuum cleaner!!
malkoff junkie
thanks, the plug, – one is 5A other is 13A, one was for charger , and I bought a camera charger and battery too. just got mixed up.
thanks gravel monkey.
Malkoff !
gravelmonkey
I’m not an electrician but I wouldn’t have thought either should have 13A fuses in…?
how2
Last seen: 2 days 9 hours ago
Its going to be the 5 amp plug notb 13 amps. 13 is for tv, kettles etc.
SammysHP
SammysHP's picture
Last seen: 26 min 20 sec ago
Can you please show us a picture of the cables?
