S21A thermal protection
13 posts / 0 new
YuvalS
YuvalS's picture
Last seen: 18 min 57 sec ago
A friend, bought a S21A (4 modes) and it seems like it does not have thermal protection (or the protection is not working)
After few minutes on the brightest settings the light getting too hot for holding but not stepping down.
Can you recommend an alternative driver with thermal protection or even better, a FW for burning on the original driver
THX
My FW repository
My BLF/OL contest entries: 7th 8th 9th
lfb
Last seen: 11 hours 52 min ago
Have you tested the output on turbo with a lux meter?(some apps can do it). I’m asking this because the thermal throttling is very subtle, and you may not see it. Also, even with thermal protection the light can become hot for some people.
YuvalS
YuvalS's picture
lfb wrote:
Have you tested the output on turbo with a lux meter?(some apps can do it). I'm asking this because the thermal throttling is very subtle, and you may not see it. Also, even with thermal protection the light can become hot for some people.
I didn't test it with lux meter but it is getting hotter and hotter to dangerous temps
My FW repository
Terry Oregon
Terry Oregon's picture
Last seen: 11 hours 11 min ago
This is a runtime graph of my S21A (purchased two years ago).  The four-mode version.  It should throttle down to about 42% brightness in about three minutes.
If you read my S21A review (link in my signature), I also wrote:
Quote:
Temperature management could use some user control. Most people will not be able to hold this light for long on high. High should be considered as a turbo mode only. If the Crescendo user interface is released (which has a thermal setting), it may solve this issue.
    and
Temperature readings taken with a Fluke 62 Max Plus IR Thermometer.
As you can see, the temperature gets HOT rather quickly. After fifteen minutes, the light was too hot for me to hold.
Note this light now comes with a 12 mode group, with some of the modes having 50% as the top brightness level.
My reviews: , My personal collection of lights LINK,  J5 Tactical V1 Pro review LINK,  Thirteen Optical Sensors review LINKZebralight SC700d review LINK,  Ray-O-Vac Super Power Sportsman review LINK,  Convoy S2+ color combos LINK,  How To flash D4V2 LINK,  Convoy S21A LINK
YuvalS
YuvalS's picture
 Yes it is getting REALLY hot, I want to change driver or FW in order to decrease temperature after about 1 min
My FW repository
lfb
How much is REALLY hot? (Celsius degrees). If thermal protection is not working properly you may have a defective driver. If he bought the light from Simon, he may be able to send a new driver if you prove objectively that thermal protection is not working. Or you can just select the third mode (30%) to prevent overheating.
I think that doesn’t worth buy a new driver. If it is working properly and he wants a cooler light, I would choose one with anduril to control the temperature or with one buck driver that is more efficient and generates less heat. I have a s2+ with 5A driver and I can’t hold the head after some time on turbo and some people can’t even hold the body.
zoulas
zoulas's picture
Last seen: 15 hours 7 min ago
It’s funny, most enthusiasts pay extra for a light w/o ATR.
NeutralFan
NeutralFan's picture
Last seen: 1 day 6 hours ago
You could replace the driver with the other driver that comes with the S21A: 20mm Driver for SST40 ,12groups , max current output 6000mA, Temperature protection management inside
And set it to mode group 8 which is 4 modes and highest at 50%. I’ve done that with some of my flashlights to limit the current. Certainly less output, and will eventually heat up, but still plenty bright at around 3 amps.
I’d rather use my flashlight around the house than turn on the lights.
YuvalS
YuvalS's picture
zoulas wrote:
It's funny, most enthusiasts pay extra for a light w/o ATR.
But he is not enthusiasts Smile
NeutralFan wrote:
You could replace the driver with the other driver that comes with the S21A: "20mm Driver for SST40 ,12groups , max current output 6000mA, Temperature protection management inside":https://www.aliexpress.com/item/4000961062843.html?spm=a2g0o.store_pc_gr... And set it to mode group 8 which is 4 modes and highest at 50%. I've done that with some of my flashlights to limit the current. Certainly less output, and will eventually heat up, but still plenty bright at around 3 amps.
Thanks, Seems like a good option.
My FW repository
lfb
NeutralFan wrote:
You could replace the driver with the other driver that comes with the S21A: 20mm Driver for SST40 ,12groups , max current output 6000mA, Temperature protection management inside And set it to mode group 8 which is 4 modes and highest at 50%. I’ve done that with some of my flashlights to limit the current. Certainly less output, and will eventually heat up, but still plenty bright at around 3 amps.
I don’t think he will get a lower temperature. The temperature threshold will remain the same, it will just take longer to be achieved. Unless the sustained power is over 50%, then he’ll get a lower temperature. But usually the flashlight throttles down to around 30%, and, once it does that, doesn’t make any difference be in 100% or 50% mode.
NeutralFan
These Convoy drivers are supposed to max out at 55 degrees Celsius, which is not that hot. So it seems there is something wrong with the driver if the S21A is getting too hot to hold.
Mine will get very warm, but never too hot to hold. And I have 8 of these drivers.
I just measured one in 100% mode and it maxed out at 58 degrees Celsius, but then settled down to around 43 degrees after several minutes.
I then measured it at 50% mode and it maxed out at 52 degrees after several minutes, and then settled down to 43 degrees once again.
aan
Last seen: 2 months 41 min ago
My S21A came with 12 group mode.. (red PCB driver with V20 text on the batt side. yes it get hot really quick but i measure it goes to around 50C max and i know the thermal protection works becouse its goes down to about 48 and stays there
Terry Oregon
If you can get access to an infrared temp meter, you should get close to this.
