<New Flashlight> ANEKIM launches NM1 tactical longest range hunting flashlight
10 posts / 0 new
ANEKIM US
ANEKIM US's picture
Dear BLF buddies
Nice to meet you, this is my first time posting and I will show you more in the future.
My name is january
We are happy to announce the launch of our longest range hunting flashlight/home defense helper-UC20.
We have prepared two types of flashlights for this series.
<1.>UC20 KP CSLNM1.F1 --- Green hunting flashlight
<2.>UC20 KW CULPM1.TG --- White light hunting flashlight
Professional smooth electroplating reflector technology can provide a maximum output of 1,586 yards and 1,300 lumens, helping you create ideal conditions for long-distance scanning of eyes or trajectories.
Provide a truly tactical single-mode green hunting flashlight: KP CSLNM1.F1 green LED light is invisible to animals and will not scare animals, and its large beam cannot be seen from the side, hiding itself.
Full metal matte black shell-allows you to achieve the best balance of lightweight aviation grade and weight. Our combat torch has a protection level between IP68, so you don't have to worry about it, hand or robot.
It is easy to assemble and disassemble, for example, it can withstand 0.308 or 0.30-06 caliber shots. With constant button switch and instantaneous pressure switch (2 modes), it can meet different tactical needs.
The most popular battery cell is the 18650 (18mm×65mm) battery, which is made of high-quality materials and has high operating efficiency. High-quality materials are more practical and reliable for 4 hours.
The biggest feature of UC20 is the use of automotive-grade LED core technology; compared to small-sized products, it has the farthest distance and the most favorable price.
If you want to know more about the longest distance hunting flashlight-UC20. You can contact with me
Thank you
January
january@anekim2021.com
查看 imgur.com 上的帖子
查看 imgur.com 上的帖子
查看 imgur.com 上的帖子
查看 imgur.com 上的帖子
查看 imgur.com 上的帖子
查看 imgur.com 上的帖子
查看 imgur.com 上的帖子
查看 imgur.com 上的帖子
Edited by: ANEKIM US on 06/05/2021 - 05:48
skinny_tie
skinny_tie's picture
Last seen: 4 days 21 hours ago
Welcome to BLF ANEKIM US. It’s always nice to see a new brand here.
The mounting of the LED in UC20 looks unusual. Could usually provide some more details about the construction and thermal path?
Edit: I’m not sure how fair it is, but covered springs and bare threads at both ends of the body tube are flashlight quality red flags for me.
freeme
freeme's picture
Last seen: 9 hours 27 min ago
Super cool bezel. tongue-out
1thedeals.comyoutubeAstroluxNealsgadgetsolight
Lightbringer
Lightbringer's picture
Last seen: 4 hours 4 min ago
Robin Dobbie wrote:
How is the first model of light from this company not called the Skywalker.
That’s the first thing I thought of before I even clicked on the thread.
ANEKIM US
ANEKIM US's picture
 If you want to review; I think I can give it to you for free.
You can contact my email. Thank you.
CR888
That’s why it’s called a ‘Super Bezel’ Facepalm
CR888
CR888
I like how the remote pressure switch called a ‘charging cable’ in the diagram…
CR888
ANEKIM US
ANEKIM US's picture
Firelight2
Firelight2's picture
Last seen: 5 hours 6 min ago
Looks like the LED is mounted on a pillar with a plastic insert on top. The pillar goes into a recess in the bottom of the TIR optic.
This appears to be a fairly standard LED-Lenser style zooming TIR optic construction.
With this kind of construction, the pill is typically made from a block of aluminum with a machined pillar rising from the center. A small star with the LED sits on the top of this pillar with the driver wires running down the sides. The plastic cover screws down and holds the star firmly to the pillar while also providing a more decorative appearance when looking into the front of the light when it is off. If it is like an LED Lenser there should also be some thermal paste between the small star and the pillar.
From the picture, the narrow heat sink fins just above the battery are probably the portion of the head where the pill screws in. Those heat sink fins are where most of your cooling occurs. The wider heat fins surrounding the pillar are probably on the sliding bezel. They likely don’t do much for cooling since an o-ring probably keeps them from touching the head.
Lightbringer
Fwiw, I posted a review of the UC20 right here on BLF
https://budgetlightforum.com/node/78414
