12 V to 12v deep cycle?
11 posts / 0 new
lampliter
lampliter's picture
Last seen: 2 days 1 hour ago
What would happen if I hooked up a 100ah car battery to a 101ah deep cycle battery (in parallel)?
“He can compress the most words into the smallest idea of any man I know.” —Abraham Lincoln
gravelmonkey
Last seen: 6 days 1 hour ago
Why would you want to…?
zoulas
zoulas's picture
Last seen: 6 hours 21 min ago
Oli
Last seen: 1 day 1 hour ago
Nothing funny would happen. They would charge and discharge together. If one was older and not holding a charge as good as the other one it would suck the good one down to its level.
Scallywag
Scallywag's picture
Last seen: 3 days 6 min ago
You’d get a sort of hybrid of the two (if in parallel), where you have a bit more capacity and a bit more peak output.
It’s important to understand that the construction of the two internally is rather different. Starting batteries are focused on surface area of the lead plates to deliver peak energy outputs, while deep cycle batteries focus on thicker plates to support and withstand deeper discharges. Real starting batteries never want to be deeply discharged and just a few deep discharges can ruin them.
kennybobby
kennybobby's picture
Last seen: 34 min 49 sec ago
If they are not at the same voltage then you will have some current between the two until the voltages are equal.
Now i used to think that i was cool,
drivin' around on fossil fuel,
until i saw what i was doin',
was drivin' down the road to ruin. --JT
Oli
You could also add a riding lawn mower battery or a motorcycle battery to the mix.
Lightbringer
Lightbringer's picture
Last seen: 1 hour 52 min ago
You could put a Hell of a lot of them in parallel and see if they’ll pop a 5000A fuse.
MtnDon
MtnDon's picture
Last seen: 11 min 32 sec ago
What will happen after they self-balance voltage, will depend on what you do with them.
lampliter
lampliter's picture
Thanks all; I just replaced my car battery because it was old and not holding a charge; I keep the marine battery hooked up to a solar panel jic. Then I wondered—————now I know; it ain’t gonna happen. Grad
wle
wle's picture
Last seen: 4 hours 19 min ago
5000 amp fuse:
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
