Test/review of Vapcell INR21700 5000mAh P2150A (Black-purple) 2021
5 posts / 0 new
HKJ
HKJ's picture
Last seen: 5 days 4 hours ago
DSC_4500
Official specifications:
  • Model: INR21700 5000mah 10A
  • Size: 21.1*70.5mm
  • Typical Capacity: 5000mAh (0.2C discharge)
  • Min capacity: 4800mAh (0.2C discharge)
  • Nominal voltage: 3.60V
  • Max Continuous Discharge Current: 10A
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.5V
  • Weight: 76g ( Appr)
  • Internal resistance: 28mOhm ( Appr) AC 1kHz?
  • Standard Charge: 1500mA,CCCV 100mA cut-off
  • USB charge model : CC CV
  • USB input power : 5.0v ,>1.0A
  • USB end-of-charge voltage : 4.20V
  • USB CC mode charge current: 1000mA
  • USB CV mode charge current :100mA
  • USB output : 5.0v ,max 1.5A
  • Over charge protection voltage: 4.25+0.1/-0v
  • Over discharge protection voltage 2.50+0/-0.1V
  • Over current protection current: 12A ~ 18A
Vapcell%20INR21700%205000mAh%20P2150A%20(Black-purple)%202021-info
This is a high capacity 21700 LiIon battery with USB-C charging input and the USB-C connector can also supply 5V output, i.e. it can work as a power bank.
DSC_4499
DSC_4501 DSC_4502
There is a multicolored led behind the hole in the plus pole, it is used for charging and power bank functions.
DSC_4503
DSC_4504
DSC_4505
DSC_4506
Vapcell%20INR21700%205000mAh%20P2150A%20(Black-purple)%202021-Capacity
The two cells tracks nicely and can deliver the rated 10A.
Vapcell%20INR21700%205000mAh%20P2150A%20(Black-purple)%202021-Temp-7.0
Vapcell%20INR21700%205000mAh%20P2150A%20(Black-purple)%202021-Temp-10.0
Vapcell%20INR21700%205000mAh%20P2150A%20(Black-purple)%202021-CapacityTimeHours
Vapcell%20INR21700%205000mAh%20P2150A%20(Black-purple)%202021-Energy
Vapcell%20INR21700%205000mAh%20P2150A%20(Black-purple)%202021-PowerLoadTime
Vapcell%20INR21700%205000mAh%20P2150A%20(Black-purple)%202021-TripCurrent
Vapcell%20INR21700%205000mAh%20P2150A%20(Black-purple)%202021-Charge
USB%20Charge%20Test%2020210705205303
The battery only increase temperature with about 10°C during USB charging, but the rated 1A charge input current is not correct, it is 1.5A
The USB-C input uses resistor coding to decide between charging and power bank, but it ignores any current rating on the USB-C port.
Discharge-Vapcell%20INR21700%205000mAh%20P2150A%20%28Black-purple%29%202021-pulse-1.0%2010%2010-IR
Power bank
USBLoadSweep
USB-C output is rated at 1.5A and can deliver a bit above 1.6A, that is fine.
USBDischarge0.5A
At 0.5A load it can deliver above 3Ah, i.e.more than 6 hours of power. It turns output off when battery is down to about 2.9V.
USBDischarge1.5A
At 1.5A load it can deliver nearly 3Ah, i.e. about 2 hours of power. I did check the temperature during discharge and it was not more than a 14°C increase at the front of the battery (i.e. the boost converter).
10ohm
Noise is 62mVpp and 8mV rms at 0.5A
5ohm
Noise is 62mVpp and 8mV rms at 1A
Conclusion
This battery works fine, both as a battery and as a power bank.
I am not sure that building a power bank into a LiIon battery is a good idea, it would at least require plastic cap to place on the plus pole of the battery when used as a power bank, to prevent any shorts from the plus pole.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Renato Azevedo
Last seen: 9 hours 47 min ago
Great review, very detailed
Thank you
GhostJoe
Thanks a lot HKJ. This one has a bottom vent, a hallmark of LISHEN cells. Is it LR2170SD?
HKJ
HKJ's picture
GhostJoe wrote:
Is it LR2170SD?
I have no idea, but somebody has talked about getting my some Lishen cells, if that succeed it may be possible to compare them.
Oli
Last seen: 1 day 7 hours ago
Acebeam has had a 21700 5000mha (now 5100) type C in and out for almost 2 years and they put it in a few of their lights and sell it separately. For about a year prior to that they had probably the same battery with a micro USB in and out. I measured the micro USB one at just over 0.5 amp out. It came in the Acebeam W30. Manker has a 13650 with C in and out. I think somebody has one with a 18650 also. I suppose in a pinch the power bank might come in handy once in a while with the 21700. And the charging feature might be useful for some people more often.
