WUBEN B2
Osram P9 1300lm 280m Rechargeable Bicycle Light Group Buy
For reference, this is my order (gray) timeline for our Group Buy.
Note: speed of delivery varies from country to country.
Group Buy Price: $32.99 (usual $39.95)
Freeme's Exclusive Coupon: FWUBENB2
Can't wait for our reply??
Coupon: To be Announced
Features:
1300lm High Brightness: Utilizes 10W 6500k P9 LED and a lens that combine spot and flood, B2 is designed to be more suited for cycling.
280M Beam Distance: B2 bike light has 280m
beam distance, which widely expands the area of visual range to better ensure your visibility and safety at night.
6 Modes Adjustable: 4 default output selections and 2 flash modes, meet your needs for various scenarios.
IP68 Waterproof: Still providing a stable and continuous illumination even if cycling on rainy days.
Specifications:
Turbo | High | Med | Low | Beacon | SOS | |
Lumens | 1300-1600lm | 1000-400lm | 400lm | 200lm | 400lm | 400lm |
Runtime | 1min+2h | 3min+7h | 5h | 7h | / | / |
Beam | 280m | 246m | 156m | 110m | / | / |
Candelas | 19650cd | 15115cd | 6046cd | 3023cd | / | / |
Weight | 186g | |||||
LED type | 1xP9 LED | |||||
Impact resistant | 1.5m | |||||
Waterproof | IP68 (2m underwater for 1h) | |||||
Size | 121x36mm / 4.76x1.42inch |
Operation
A Main Light Operation
1. ON/OFF: When the light is off, single click on the "w" switch to turn on the light, long press the "w" switch to turn it off. The bike light has memory function, will memorize default output selections, but not flash modes.
2. Default Output Selections: When the main light is on, single click on the "w" switch to cycle through High-Med-Low-High.
3. Quick Turbo: When the main light is on, double click the "w" switch to activate Turbo, single click to return to the previous output level.
4. Flash Modes: When the main light is off or at Turbo mode, double click the "w" switch to cycle throught Beacon-SOS, single click to exit.
B. Breathing light:
When the light is off, triple click the switch to turn on/off the blue breathing light. The breathing light has power-off memory function.
Package Included:
1 x WUBEN B2 Bike Headlight
1 x Battery Tube
1 x Type-C Charging Cable
1 x Bike Holder
1 x 18650 Battery (Built-in)
1 x Taillight
1 x Bandage
1 x USB Charging Cable
2 x Spare O-ring
Images:
https://1thedeals.com/blf-flashlight-group-buy/
