[REVIEW] Emisar DT8 - Osram W2 & Nichia 219b SW35
9 posts / 0 new
LuxWad
LuxWad's picture
Last seen: 9 hours 40 min ago
Video Review of the Emisar DT8. This is an awesome little hotrod that provides a crazy output in a package barely larger than the D4V2. It is definitely aimed at enthusiasts, and is not very practical overall. I love using these lights, and I think they’re an awesome addition to a collection, but I can’t recommend them to most users looking for a practical light.
TLDW:
What I like:
  • Crazy high output
  • Compact with a great comfortable-to-hold form factor
  • Great build quality
  • Emitter choices
  • Anduril 2
  • AUX LEDS!
  • 219b light has a fantastic beam
What I don’t like:
  • HEAT – this thing gets crazy hot! Unavoidable, but an issue nonetheless
  • Beam quality on the W2 model isn’t great
  • Not really great for pocket carry
  • I still think a 21700 version would be better, with more reasonable runtimes
I tested this light with the Molicel P26A, Samsung 30Q, and Keeppower 10A 18350. The 219b model is using the KR4-219b.hex, which provides 11% lower output on Turbo than the firmware which came loaded onto the light when I got it (60% vs 50% FET). This is not really a visible difference, and less heat is produced.
The W2 light’s thermal limit was set to 55C. I am not guaranteeing that my measurements are super accurate, but they should give a good idea of the performance between these two.
The W2 model with the P26A produced 8,600 lumens on Turbo @ startup, the 30Q 7,800 Lumens, the KP 18350 5,700. This is an incredible amount of light, and is extremely impressive for such a small flashlight!
The 219b is much less bright, with both the P26A and the 30Q producing 3,200 lumens @ startup. The KP produced 2,300 lumens. Not as impressive, but this is still a ton of light, and more importantly all of it is a beautiful warm color with high-CRI and awesome tint.
Of course, these lights get extremely hot very quickly, and Turbo drops very fast. After step-down, the output on the W2 will vary between 500-750 lumens, while the 219b will produce 190-275 lumens. This is pretty good for sustained output from a single 18650, but honestly I hoped for a bit more.
High will produce 2,100 lumens on the W2 and 1,900 on the 219b, with the stable level on both being the same as Turbo after step-down.
Emisar DT8 Review Measurements – Osram W2 vs Nichia 219b
Standby drain on the Aux lights is basically the same as the D4V2. Because the High levels are really high, they will drain a lower-capacity cell like the P26A pretty fast, so I have mine set to automatically lockout after 30 mins (with low AUX) to save battery and provide some extra safety.
Low:
  • Red:0.09 mA
  • Yellow: 0.1 mA
  • Green: 0.07 mA
  • Cyan: 0.09 mA
  • Blue: 0.06 mA
  • Magenta: 0.1 mA
  • White: 0.12 mA
High:
  • Red: 3.58 mA
  • Yellow: 4.08 mA
  • Green: 0.81 mA
  • Cyan: 1.22 mA
  • Blue: 0.7 mA
  • Magenta: 3.97 mA
  • White: 4.47 mA
Off: 0.04mA with regular jumps to 0.26 mA
Ultralow has been dramatically improved with ToyKeeper’s latest updates to Anduril on these drivers. On 1/150, I measured 1.8 mA on the W2 and 2.08 mA on the 219b. Both were so dim that I couldn’t properly measure the output, all I can say is that they are no brighter than 0.07 lumens.
Beam quality on the 219b model is excellent, with a lovely warm (3500K) rosy tint, and the floodier beam is clean and very useful for most illumination tasks indoors and out, though there isn’t much throw unless Turbo is used. I measured 4.3cd/lumen, for a maximum of 14,262 cd.
The W2 has a much less pleasant beam, being cool white and low CRI. There is a noticeable greenish tint in the outer edge of the hotspot, and the spill is full of rings and artifacts. The hotspot is tight and throwy, providing 9.9 cd/lumen with a max of 89,130 cd. I do not like this beam, but honestly I’m willing to accept it for the incredible amount of light that comes out of here. For practicality and real usage though, the 219b is easily superior.
Overall, I really enjoy using these lights. While I do still think a 21700 version would be better, I understand why Hank opted for this form factor. For all intents and purposes, this is basically the D4V2 EXTREME EDITION, and I have come to really appreciate this design – I want more square flashlights now! However, this is not the kind of light I feel comfortable recommending to most people unless they really know what they’re getting into. If you are an enthusiast, the DT8 is an awesome little light to add to your collection.
These lights were both sent to me by Jackson Lee for the purposes of review. The video description does have 5% discount codes for his webstore jlhawaii808.com and his eBay store. I was not otherwise paid for this review, the discount codes don’t give me anything. All opinions here are my own.
Also, this is the second time I wrote this review, the first time as I tried to post the site went down for maintenence and I lost everything I wrote Facepalm
Anyways thanks for reading/watching!
My Review Channel - https://www.youtube.com/luxwad
Edited by: LuxWad on 09/24/2021 - 17:32
sb56637
sb56637's picture
Last seen: 1 hour 37 min ago
Ooops! My sincere apologies! (Normally it should stay in the browser cache if you hit the back button.)
Really glad to have you (and your reviews) on BLF. Well done! Looking forward to the next ones.
Firelight2
Firelight2's picture
Last seen: 19 min 28 sec ago
Fantastic review!!! Crown
id30209
id30209's picture
Last seen: 5 hours 49 min ago
Awesome review!
That's the kind  (of quality) we need here!!
WTB Titanium 4sevens 2xAA tube
LuxWad
LuxWad's picture
Haha it’s okay, funnily enough I had this gut feeling that I should save my review as a doc first before posting it here… but I didn’t do that.
Thanks for the welcome! I’ve been lurking here for a while, but only just started posting. This is a great place, one of the best communities online Smile
id30209 wrote:
Awesome review!
That’s the kind  (of quality) we need here!!
Thanks!! I’m really glad you guys enjoy the reviews! Big Smile
raccoon city
raccoon city's picture
Last seen: 14 min 23 sec ago
Please enjoy your time here, LuxWad!
208_milla
LuxWad
LuxWad's picture
Haha thanks, so far I have
…I wish there was a decent laughing emoji though
xevious
xevious's picture
Last seen: 24 min 48 sec ago
What took you so long to get here, LuxWad? Wink
Man… your video review looks amazingly professional. Super job. Is your day job in the videography or photography domains?
I’ve still put off getting a DT8 for the main reason you stated — lack of 21700 support. Frankly, this light is in a weird zone—too big to EDC in a pocket, but too small to adequately manage the generated LED heat.
I’d really like to see Hank come out with a DT8S, “S” for “Super.” A little larger head with more aggressive fins, improved thermal pathway, and 21700 cell support.
Btw, friendly tip on writing content on any forum: once you get a decent amount of content written in the editor, do a select all and copy. Get that stuff in the paste buffer. Or you can keep a lightweight text app running on the side to dump versions as you go. I’ve saved myself a lot of headaches this way.
LuxWad
LuxWad's picture
Haha, I took a while because I’m actually a bit nervous about sharing things online, BLF seemed a bit scary for a while. I’m glad I started posting here though!
I’ve been producing video content for a long time, only in the past couple years have I been doing it professionally. Nothing crazy, I’m still relatively new to it. I aspire to be a film director someday, and my education & work is striving towards that. I prefer not to give too many personal details though Smile
I like flashlights of course, but these videos serve a very important auxiliary role for me: they provide extra filming/editing practice, and help me to experiment with new and fun video production techniques. I get to improve my filmmaking and review flashlights, so it works out very well.
I think this would be ideal, the DT8 is a great little 18650 light but the small hotrods aren’t really my thing, I prefer bigger lights which can sustain their output and provide long runtimes.
I’ll have to start doing this now LOL
