I have a light that I’m trying to add a lighted switch to.
The driver is a BLF Mtn 15mm driver with Guppydrv Rev1 firmware.
The lighted switch has 2 tiny leds each with a 910 ohm resistor.
With the lighted switch the driver malfunctions. Off-time memory doesn’t work, so the light always cycles to the next mode every time the switch is clicked full or half press.
I’ve tried each of the following as bleeder resistors between the positive and negative on the underside of the driver: 330, 510, 750, 910 ohm.
Nothing works.
Any suggestions? Should I change the resistors on the SMD on the switch? Or should I try a different value for the bleeder resistor and if so what?
Swapped the resistors on the switch for a 7,500 on the blue and 75,000 on the green, with a 510 ohm bleeder resistor. The switch is much dimmer now, but it does its job of letting me find the light at night.
