so i have a few extra 21700 cells laying around i have 2 throwers which is perfect for my needs. Now im on the hunt for a more floody 21700 light. i was looking at the m21b with gt fc40 emitter but was also looking at the s12 not sure on which emitters yet. Anyone have a solid suggestion for another option that wont break the bank lets say 50 or less
You can just ask Simon to put in a XHP70.2 and see if he can do it. I have a light from a brand called Pioneman and it’s basically a small 21700 light with a XHP70.2 light and a Convoy 6V 5A driver. Mine outputs about 3500 lumens and it can sustain that for 2 minutes. The beam from a XHP70.2 will tend to be very even and nice.
Yes, being a 45mm head you might be right back into throwy not floody territory. I have the M21e with a smooth reflector and the 5000k XHP70.2, she has a wide very well defined hot spot with a decently wide spill. In comparison Simon’s M3 with an op reflector of the same size has less defined hot spot and slightly wider spill.
