This cheap bench power supply: good enough for flashlight related stuff?
10 posts / 0 new
ChibiM
ChibiM's picture
Last seen: 19 hours 41 min ago
I'm about to pull the trigger on a cheap power supply, currently on sale at Banggood.
Since I'm a total noob to this, I'd like know if this would be an okay choice,
This has 30V 10A, and some other have 60V 5A... and I don't think I need anything above 30V, so more amps could be useful if I ever need it.
Any comments on this one?
https://www.banggood.com/TOPSHAK-K3010D-4-Digits-LED-Display-110V-or-220V-30V-10A-Adjustable-DC-Power-Supply-Switching-Regulated-Power-Supply-p-1419678.html
or
https://www.banggood.com/Topshak-NPS3010W-110V-or-220V-Digital-Adjustable-DC-Power-Supply-0-30V-0-10A-300W-Regulated-Laboratory-Switching-Power-Supply-p-1474957.html
Just to test LVP,
and maybe check if an LED/Driver is dead or what not.
Haven't thought about other use cases at the moment.
CNCman
CNCman's picture
Last seen: 7 hours 59 min ago
How to use a bench power supply, HERE , HERE , HERE
I purchased a different model HERE. on Ebay.
Wish I had purchased this one instead, HERE
This one is programmable. But I am no electronics guy, so maybe someone will give you some advice. Wink
I wanted this one for anodizing and bench testing high amp leds and drivers but decided its not worth the trouble. HERE
Charging lithium batteries, HERE , HERE
CNCman
CNCman's picture
HERE is a review on the Topshak NPS3010W .
djozz
djozz's picture
Last seen: 6 hours 20 min ago
I have a power supply of the second type, 60V 5A version (different brand, same PS), and a)the lowest currents are not accurate which limits usability when working with leds, b)I get spikes at switch-on that make leds flash so I’m afraid it kills leds.
wle
wle's picture
Last seen: 7 hours 34 min ago
you will need a good current-limiting mode , and go way down to about 1mA at most
which you may find hard to get
LEDs work on current, the cheap power supplies give a good regulated constant voltage, but may not provide low- or any current limiting
wle
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
djozz
djozz's picture
That makes me think, if you are interested you can have mine and see if it works better for you than it does for me. The brand is Wanptek, it is a 30V 6A version.
Personally I like the Gophert brand power supplies that Banggood sells. The way they operate, digitally adjusting the settings with one knob, is a bit awkward, and may be unhandy for how you want to use it, but they seem very accurate and well-build for a good price. I have the 32V 5A version (it runs my reflow heatblock) and am very happy about it.
ChibiM
ChibiM's picture
Thanks for all the info and links.
That's probably why I hadn't bought one before Big Smile ... lack of knowledge.
Have been looking at some local second hand market places, but never pulled the trigger.. And the one time I pulled the trigger, they didn't want to send it... lol
I have some BG points that I want to use, so I'd first love to see if there is one at BG.
Djozz, so you think those Gopherts might be a better deal /  better quality?
djozz
djozz's picture
They get good reviews all the time and I have the impression that they are designed by some clever folks. I can not really tell by own experience because I use mine in a rather limited way, I just adjust the current slightly to set the temperature of the heatblock. But it works for years now. So if you can live without the convienience of a complete set of adjusting knobs, yes I think they are a good deal.
But maybe someone here on BLF has one for a second/better opinion?
ChibiM
ChibiM's picture
Oh yes, I noticed the missing knob...
Not sure how often I would like to change the output, but I'm pretty sure I'd like to dial things up and down.... hmmmm
dave1010
dave1010's picture
Last seen: 7 hours 31 min ago
One of these USB ones may be enough, depending on what you want it for
https://budgetlightforum.com/node/78771
I have 1 that I use for measuring but haven’t really tried powering stuff with it.
