More battery efficient flashlight, is there such a thing?
19 posts / 0 new
dee-u
Last seen: 2 hours 12 min ago
For instance, flashlight1 and flashlight2 uses the same battery and as lighted on the same lumens (200 lumens perhaps), would there be an instance where flashlight1 will last longer than flashlight2?
niajef
Last seen: 1 week 5 days ago
yes. depends on the LED outputting that 200 lumens, and depends on the driver
dee-u
Thank you for the very prompt response. What are the types of LED/drivers which are more energy efficient? I am actually curious since I am after a longer runtime when looking for flashlights.
bobvoeh
Last seen: 1 hour 16 min ago
It would seem my monitor has a bug inside of it now.
dee-u
You will be fine as long as you will not hit it with a hammer. Big Smile
niajef
LEDs i dont know, but im sure tons of people on here would know, drivers, buck and boost would be considered efficient compared to the cheaper FET and linear
iamlucky13
Last seen: 5 hours 53 min ago
A variety of users have done their own tests of flashlight output and runtime, which can be used to calculate efficiency. Because the accuracy of each person’s gear may varied, they shouldn’t be assumed to be exact comparisons, but can help give a sense.
Zak is one such reviewer, and a member here, and often will take the effort to calculate efficiency. I think this might have been the highest efficiency model he tested:
https://zakreviews.com/thrunite-tc20v2.html
Lumen9000
Lumen9000's picture
Last seen: 22 hours 34 min ago
Lights with Xhp 70.x or xhp35hi will always need boost drivers to work and most often sustains over 1000 lumen with ease.also look into convoy m21E and convoy M3-c.
YuvalS
YuvalS's picture
Last seen: 19 min 59 sec ago
the answer is in Lumen to Amper  graph
And easier to understand using lumen to Amper  to lumen
This data is for XM-L2 but all leds have similar behavior
1. Obviously the beter lumen to amp ratio the more efficient the led so first step to increase efficiency is by choosing best emitter with lumen to amp (or lumen to watt) ratio
2. As you can see it starts linear. ie constant lumen to amp ratio - it called "linear section" and for this range of amps the LED is more efficient so you want to keep your light in this range
Your question is for 200 lm so you can think that you are in the linear section but it is only true for constant current drivers.
PWM driver actually working in the highest current allowed by driver so far off the linear section so 2nd way to improve efficiency is using constant current driver
3. we now now that led is more efficient on lower currents so 3rd way to improve efficiency is to divide the same current among more LEDs instead of driving 1 led with 3amps fo 1000 lm, drive 3 leds with 700amp each and get tand get combined 1000 lumens output for only 2.1amp
My FW repository
My BLF/OL contest entries: 7th 8th 9th
Quadrupel
Quadrupel's picture
Last seen: 10 hours 51 min ago
First you have to keep constant 200 lumen, so you need stabilized output driver. Read more about DC-DC converter types. About linear and switching topology . Its important to use low resistance contacts and switches. Overpowered led is loosing efficiency too and so on.. Its whole science about it Smile
dee-u
Thank you guys, I will need more time to digest the knowledge you’ve imparted. Some terms used are greek to me.
how crazy is this
Last seen: 8 hours 8 min ago
I am not sure how to express this but there is one thing that has always completely amazed me in terms of efficiency and that is useful light per watt. By that I mean that most of my lights at say 80 or 100 mA will be very useful flashlights. Bump that up to an Amp and they are really putting out some light and of course if your looking for throw it may be required. However, 10X the energy for an apparent doubling or so in perception makes the lower levels seem fantastically more efficient to me. I believe that this goes beyond the efficiency differences at lower levels and gets to perceived brightness as well. What to they say something like 4X the lumen to seem 2X as bright?
Lightbringer
Lightbringer's picture
Last seen: 3 hours 34 min ago
It’s not a bug, it’s a feature.
wle
wle's picture
Last seen: 7 hours 54 min ago
something like that
it is not linear, as you found out
100 lumens does not seem twice as bright as 50
the leds also start to be less efficient at higher currents
1 watt in might be 200 lumens out
but 10 watts in might be 1200, , instead of 2000
wle
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
Scallywag
Scallywag's picture
Last seen: 2 hours 49 min ago
Zebralight SC700d is very good, even though it’s taking about 30% hit from high cri led. There’s a Fenix that’s 21700 and XHP70.2 (low cri) if the Thrunite, linked above, with 26650 isn’t to your liking.
Acebeam E70 is another good one.
Lightbringer
rayfish wrote:
Take a 2×18650/CR123 (Buck Driver) Flashlight with ramping and top lumen Chip or “PC green” (from phosphor), and use it at as low as possilbe.
Yep, and the nice thing about PC green is that even though it’s a dominant green, it’s not perfectly monochromatic, so you’re not seeing just a stark green’n‘black, but can still see some other colors from red to blue just fine, albeit subdued.
I got a pair of Anekim UC20 and UC10 with PC green emitters, and they’re quite nice. Not harsh at all.
maxl96
Last seen: 1 week 1 day ago
Can someone explain this graph to me?
I am struggling with it for 10 minutes now.
YuvalS
YuvalS's picture
Sorry maxl96, I did a lot of mess in this graph
Here is the correct set:
My FW repository
dee-u
2. As you can see it starts linear. ie constant lumen to amp ratio – it called “linear section” and for this range of amps the LED is more efficient so you want to keep your light in this range
With regards to the 3rd, does it mean those flashlights with more than 1 led/emitter are more efficient compared to single emitter ones?
