I need a modder to repair a older nitecore with the tube activation (not sure what it’s called) I had it repaired once by someone here but has since died. Anyone know who or if you are one please hit me up. If possible I’d like to upgrade it as well. Thanks
Sorry to hear about the modder.
Is it really worth fixing? Shipping = @$20 (two ways) + labor.
To me yes it is.
Isn’t it called a piston drive? Nitecore D10 PD, etc.
I might be able to help…
Please post a photo of the light so I can see what model it is.
Describe the problem, and what repair was done last time. What brand of battery do you use?
suggestion, if you have not already:
Clean out all lubricant in the head, threads, and body tubes, and see if that solves the problem. I use isopropyl alcohol.
here are photos of some of my Nitecores with LED upgrades:
and a thread full of info about modding those lights
It is a nitecore d10 piston drive as said above. I don’t have any pics at the moment. What was done was a driver swap and possible a emitter swap. The issue was that the post where the battery connects fell off. I soldered a new one on. Connection is good but it never worked correctly after that :/. It’s very “ finicky“ but it still works. I’d love a upgrade to newer driver and higher output led and more reliable if possible. Driver would need to use rechargeable 14500 and AA, but if I had to choose just one it would be the 14500. I will try to get some pics when I go to my shop tomorrow if I can remember. I’m not getting any younger.
