Overdischarge protection - AW vs Redilast?
4 posts / 0 new
Shadowww
Last seen: 4 hours 5 min ago
Hi there,
deciding on which batteries to give to my uncle (he works in the traffic police), but as the light is 2x 18650, I'm afraid he could get cells over-discharged resulting in, well, let's not talk about that..
So I wonder, out of two specific cells - RediLast 3100mAh and AW 2200mAh - which one has better / more reliable over-discharge protection?
BetweenRides
BetweenRides's picture
Last seen: 3 years 4 months ago
Both are highly rated, should be ok with either. Redilast will give longer run time.
EDCPlus
Shadowww wrote:
Hi there,
I have not tested the AW 2200, but I know from first hand experience that the AW 2900's protection circuit kicks on at a lower than recommended value (around 2.2-2.3v).  My Redilast cells have a high quality Japanese IC which kicks in @ 2.5v +/- 0.05v.  Also, zero failures out of thousands sold. Smile
Kokopelli
Kokopelli's picture
Last seen: 2 years 8 months ago
I don't think overdischarge is that much of a problem if you use a 2x18650 light with low voltage protection as long as you use balanced cells. I mean with a light with something like 5v -18v voltage range it cuts the light if the total is below 5v, making 2.5v for each cell. Overdischarge shouldn't be a problem other than cell life, if you're not trying to power something like 5x XML with two crappy 18650s.
