single xm-l lights /beamshots
15 posts / 0 new
viffer750
Last seen: 4 years 10 months ago
just a simple test with my single xm-l lights Smile
left to right:
-MTE modified with xm-l T5 direct drive
-Lumapower clone xm-l with amc7135 3040mA
-HS802 clone with xm-l T5 direct drive
-Jetbeam bc40
-Uniquefire X8
-Keygos ke-1600
-Ultrafire D1 with modified driver
1
2
spot comparison, the sequence is the same as above:
mouseover faster shutter speed
    mte 12kcd           luma 25.5kcd           hs802 31kcd          bc40 24.5kcd         UF X8 32kcd         keygos 37kcd         UF D1 53kcd
1
"tree shots" ~ 50-60m
mte xm-l
1
lumapower xm-l
2
hs802 xm-l
3
jetbeam bc40
4
Uniquefire X8
5
keygos ke-1600
6
Ultrafire D1
7
"building shots" ~ 150m
mte xm-l
8
lumapower xm-l (C8)
9
hs802 xm-l
10
Jetbeam bc40
11
Uniquefire X8
12
Keygos ke-1600
13
Ultrafire D1
14
unique engrish language... Smile
Edited by: viffer750 on 02/29/2012 - 16:17
dthrckt
dthrckt's picture
Last seen: 2 days 12 hours ago
nice write up and beamshots - thanks!
Why no C10 zoomie in there - yours is xml, no?   Ok, ok, because it would look totally different than everything else lol.  I haven't modded mine, yet, so I'm curious Innocent
Tecmo
Tecmo's picture
Last seen: 10 months 3 weeks ago
Nice shots!  Thanks for doing this.  I like the Keygos, good throw and a ton of spill.
turboBB
Thx for this!  The all-in-one mouse over was a great idea!!
viffer750
thanks to everyone
dthrckt,
tomorrow, If the weather permits  Smile
viffer750
1. xm-l with 50mm lens
2. xm-l with 40mm lens
both direct drive (that means ~4A)
1
same camera settings as in the first post, of course
xm-l with 50mm lens
2
xm-l with 40mm lens (mouse over -> flood)
3
xm-l with 50mm lens
5
6
dthrckt
dthrckt's picture
SealedSealedSealed
thanks!
I have two 50mm from DX but they're terrible at full focus Sad  That's really too bad because the 50mm would be awesome improvement to tractor supply 3xD zoomie...
viffer750
I don't know, mine isn't so bad.
1
Here, it is a little out of focus (third spot), but I haven't problem with it. Little distortion, but hey, it was $3. Smile
viktori
viktori's picture
Last seen: 5 years 4 months ago
1
xm-l with 50mm lens
5
6
Can we have more info on these? Is there a separate post? The host, build, more pictures of the assembly?
Thanks!
Viktor
This is my flashlight collection.
viffer750
a moment...
this is the 50mm aspherical light:
1
The lens fits perfectly into the tr-500 tr-1200 head. I made a copper pill, heatsink, what I pressed and glued into the battery tube. Now it works with 1 cell.
this is the modified SMALL SUN ZY-C10-S:
I threw away the orig lens and replaced with a better one. I had to lift up the emitter, because the focal lenght of the lens is short.  Now the original bezel doesn't fit, temporary got a protective plastic bezel.
viktori
viktori's picture
Any chance of you opening up a new post (or two) with more details on each?
More picz! Big Smile
Viktor
Techjunkie
Techjunkie's picture
left to right:
-Jetbeam bc40
-Uniquefire X8
-Keygos ke-1600
Can you give us some details on the driver mod?  Was it an upgrade or a repair, what's the difference before and after, which replacement driver did you use?  Thanks.
*EDIT* Nevermind, I think I found it... here (posts #50 and #70).  Thanks!
viffer750
Techjunkie wrote:
left to right:
-Jetbeam bc40
-Uniquefire X8
-Keygos ke-1600
okay Smile
FX-32
FX-32's picture
Last seen: 5 years 7 months ago
Awesome! Thanks for sharing, very useful indeed!!
Could you post kcd readings for the two aspherics flashlights (40mm and 50mm)?
viffer750
Hard to tell an exact value, because the brightness changes through the projected die image. The upper part always the brightest. A good average value for the 50mm ~ 50-60kcd (upper part 70-80k!), and for the 40mm ~ 35kcd (upper part 45-50k), I don't know the exact emitter current, both direct drive, somewhere 4A...
