Looks like a buck regulator. R1 and R2 (in parallel for higher current capability and more accurate value) appear to be the sense resistors (0.1 Ω total). Removing one should halve the current.
But this is just guessing. I can’t really see the traces.
Your initial post sounds like you want to reduce the current (“Unfortunately, each pulls 1.2 amps from a charged 17ah SLA”). The driver is not made for delivering more current. Also – where do you intend to place the dimmer? Changing the input voltage won’t make much of a difference.
Yeah I suppose I should have been more clear. Those look like XML2, and I see paste under that big board, and the housing has fins, seems like I could at least get 25w.
If instead of removing one I bridge one with solder it should double? Though hopefully it isnt one resistor per led.
