Trustfire TR-9T6 - Stopped working
Hi,
I have a 3 cell TR-9T6 that has stopped working. Can't guarantee it hasn't been dropped or left on for a while.
Any ideas about how to problem solve it. I have charged teh batteries and checked the switch and all fine.
One of the problems is gettgin it apart? How are you supposed to get to to the LED's / drivers. So far I have managed to remove the extra battery extension and remove the glass on the front but cannot het the reflector out. I'm a bit scared to use brute force in case it is held in from behind...
Any ideas gratefully received.!!
Will
The reflector is probably screwed onto the shelf. You need to take out the driver first. Since TF uses glue, some heat and brute force is necessary to take the head/battery tube assembly apart.
I don’t have this model but some more recent 3-cell TFs. Beasts.
great - thanks!
