THRUNITE T1S mini flashlight with 1212 lumens, 184m beam, Type-C charging & magnetic tail cap. Does anyone like THRUNITE’s Med mode to Low mode step?
I went through a time where I was carrying a TN4a. Doesn’t have the lockout from firefly but perhaps the rest of the UI is the same? I actually grew to really like the UI. Typically there are three ways I want to use a flashlight. I either want the minimum amount of light so as not to disturb anyone or my night vision, as much light as I can get, or just the comfortable amount of light I expect from the flashlight. The Thrunite UI makes this simple. Just click the switch and the light comes on at the level I leave it in in memory. Hold it for minimum. Double click for max. Pretty much the way I use my Andruil lights as well.
I appreciated the step down first as, again, if I really want to go up to the max it is a double click. If I wanted to change the output it was typically because I wasn’t sure where it was at. Stepping down first protects the vision and only takes a moment if you were intending to go up. Seems odd I know but in actual use I did actually like it.
