Does anyone have a link to programming the H17f driver with a reverse clicky? All that I am able to find is the chart for the forward clicky. Thanks for the help.
Welcome to BLF, Kalsu!
Actually, it will probably be easier to configure it with a Reverse clicky.
For that, you just need to turn the flashlight ON and the make the taps you need like if it was a forward clicky.
If it is absolutely needed, I can make a video with a reverse clicky, but following the instructions and watching some videos even if they are made with forward switch will probably be enough
That did work out, thanks for the help. Initially I was letting the battery voltage blinks stop before clicking into the programing mode. Its all good now though.
