ACEBEAM Defender P17-Dual Tail Switch Tactical Flashlight with CREE XHP70.3 HI LED
The Acebeam Defender P17 bears a striking design and awe-inspiring performance and allows you to identify fiend or foe over 1,400 feet away. A CREE XHP70.3 HI LED casts an amazing brightness range between 3 and 4,900 lumens across five intensity levels as well as auxiliary strobe and SOS modes, granting you comprehensive preparedness for everyday and tactical applications alike.
Learn more: Powerful Tactical Flashlight|AceBeam® Official Store | Flashlights, Tactical Lights
_
Introducing the #DefenderP17 as the brand new dual-tail switch tactical flashlight, it comes with powerful performance, compact size and ergonomic user interface to make the first response in the operation. Easy one-hand use for tactical situations such as law enforcement, security and defense. More Info: https://www.acebeam.com/p17-tactical-flashlight
√ 4900 Lumens High Output
√ Latest CREE XHP70.3 HI LED
√ Compact Size
√ Three User Modes Available
√ Including One USB-C 21700 Rechargeable Battery
_
Can you guess the Acebeam new flashlight in the coming Black Friday? Here are a few hints: it emits an impressive 4900 lumens and features an innovative dual tail switch, allowing users to easily switch between tactical mode, daily mode, and the lockout function. Which one do you think it is?
Interesting.
Seems like the successor of the P16.
So I guess P17?
Looks interesting.
You figured it out :+1:
Defender P17: https://www.acebeam.com/p17-tactical-flashlight
Wow! I can’t believe it!
I really like that duel tail switch, and the strike bezel is a nice touch.
An exclusive list of the first photos of ACEBEAM Defender P17.
What is the Ra on this XHP 70.3 emitter?
can turbo be accessed directly from off?
Looks pretty nice. I wonder if a 5000k version will be added.
When you set Tactical Mode 1, you can access into Turbo or Strobe directly.
Very less CREE XHP70.3 HI LED 6500K currently, 5000K Unavailable.
A low Ra.
Awaiting the option for 5000k xhp70.3 HI…
Agreed.
Acebeam, it would be awesome if you had a 5000k, or even 4000k XHP70.3 HI version.
In future versions, I would also like a mode group where the mechanical switch is always turbo, and the function switch is always low. Or some kind of mode with instant turbo.
Last, I’d like a ~30-50 lumen low mode. There’s currently nothing between the 3 lumen ultra-low and 90 lumen low.
:smiley: CREE XHP70.3 HI 6500K (X75) Stock-out also
Yes there’s no reason why a dual switch flashlight should’nt have instant access to low AND turbo.
regards
Andreas
it looks great re no onboard charging - hooray! But then it has a proprietary battery :frowning:
“This battery isn’t proprietary, and the P17 happily digested every 21700 I stuck in the tube: flat top, and button top, protected and unprotected. The flat top Samsung 50S flat top did rattle around in the tube though.”
The above quote from 1lumen review of the P17
