I’ve got an original Olight Warrior X coming in the mail today. New in box, but that is a 4-year-old product, so the cell could have been sitting for quite some time.
I plan to test it with my DMM before putting it in my XTAR MC1 Plus. From what I have read, the cell must test at 2.8v or higher to be safe to charge.
…in fact, when i replaced the 18650 cells in 2 battery packs for 2 ‘forgotten’ e-bikes of my neighbour, 8 out of the total of 14 (2 × 5P7S packs) 5P sections still had just over 1 Volts remaining, the other were 0.0 Volts and were obviously toast.
So i decided to recharge the 8 sections and they turned out to be okay.
I built a 10P3S battery and a 10P1S powerbank for solar charging purposes and they work fine.
Probably less capacity than new and as 10P sections probably still only good enough for up to 20 A , but they’re free 20 Ah (approximately guesstimated) batteries.
I’ve also had a “1200mAh 10 Amperes” 18350 that was completely drained by an e-switch light i forgot about.
0.0 Volts.
This was still a newish cell (unlike forementioned e-bike cells) so i decided to try to recharge it.
It seems there was a short circuit in the cell’s internals, it didn’t want to get charged.
So then i though screw that, and i pulsed it with 12 volts from a lead acid battery with a number of very short taps.
Obviously i did this outside.
But to my surprise the thing came to life again,so i stuck it in my charger and it charged like it should and it still had at least the same capacity as before and the internal resistance is the same too.
I’m still using that cell without any problems.
Of course these extreme cases involved high quality cells, not cheap CrapFire cells or something.
But as allways, YMMV and be careful and avoid risks etcetera.
Another thing you want to watch for —- taking too long to terminate charging and how hot it gets towards the end of the charge —- If the cell is below 2.5 volts — recycle it — cells are cheap — houses and lives aren’t
I would do a capacity test if you have an opus or something similar. If it was below 3.4 volts I doubt I would even use it because cells are cheap. They’re supposed to be shipped around 3.5 or 3.6 volts. So it was below 3.4 that means it’s lost too much voltage.
Furthermore, unless it was 3.5 or 3.6 I would just get another cell. I would want a brand new cell in there instead of wondering if this thing’s worthwhile.
The light’s LVP kicks in at 2.8 volts, according to some reviews. Unless strongly suggested otherwise, that seems like a reasonable minimum safe value.
I’ll probably go pick up a surplus ammo can to use as a charge box too.
What does the low voltage protection have to do with the health of the cell? Nothing. You can put a brand new cell that meets its capacity or one that doesn’t it’s still going to go off at 2.8 volts. That’s not determining the health and capacity of the cell
It may be safe to use but I wouldn’t use it. Receiving a cell that low. The only way to find out the health of the cell is capacity test and IR Test and if it seems okay, see how it acts when you use it.
But as chops said I said earlier , cells are so cheap I wouldn’t bother with a cell that sat for 4 years and is received well under the normal 3.5 or 3.6 volt shipping voltage.
Safety is first but to me it’s also a matter of how much capacity the cell has and how it will perform. Very unlikely It will perform as well as a brand new one.
My mind sent may be a little different. 90% of my flashlights are modified. Nothing but the best cells.
You have a point in saying it should hold its factory charge for years if it’s not used, but if it has dropped a Volt over several years it doesn’t necessarily mean the cell is toast, let alone that charging it is dangerous (unless it’s a CrapFire cell of course).
Accidents happen with crappy batteries and crappy chargers that don’t shut off at 4.2 Volts or exceed 4.2 Volts or with way too much charging current or with way too much discharge current.
Trying to revive an Olight cell with 500mA is no problem when it’s still abovev2 Volts.
They use Japanese brand quality cells.
Sure, you can buy everything new, but this is still the budget light forum.
I understand. What would rather have a new flashlight that performs well with a healthy new battery or one that doesn’t perform that well because you want to use an older weeker battery.?
All about preference, choice and our expectations!
If you have no expectations stick with the older battery!
You can turn them in (get rid of them) at a depot or battery bin at the supermarket but that doesn’t mean they are actually recycled.
Recycling them is very tedious and expensive, costs a lot of energy in the process too.
Not unlike solar panels.
So they get ‘stored’ somewhere until ‘further notice’.
Yeah, in today’s joke of an economy that’s probably as cheap as a loaf of bread in the US.
