Test / Review: Keeppower 18650 2800mAh (Black)
5 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 weeks 6 hours ago
DSC_1529
Official specifications:
  • 18650 280mAh Protected Rechargeable Battery
  • Min Capacity: 2700mAh
  • Typical Capacity: 2800mAh
  • Normal Voltage: 3.7V
  • Quality Lithium Ion rechargeable cell
  • In Built Safety Circuitry
  • Maximum capacity and reliability
  • High Discharge Rate (Max 2C)
  • Protection Circuit (Against overcharge, over discharge, over current and short-circuit.)
  • 4.2 volts max voltage and 3.6-3.7 volts nominal voltage
Keeppower%2018650%202800mAh%20(Black)%204.3V-info
This battery is not the usual 4.2 volt charging, but needs 4.3 volt charging, i.e. a special charger must be used (Some hobby chargers can be adjusted for it).
DSC_1528
DSC_1530 DSC_1531
DSC_1532
DSC_1533
Keeppower%2018650%202800mAh%20(Black)%204.3V-Capacity
The capacity is slightly below 2800mAh, but very constant at different loads. The battery has a high voltage, but not higher than the best 4.2 volt batteries. Where it is better is runtime at high voltage.
Keeppower%2018650%202800mAh%20(Black)%204.3V-CapacityTimeHours
Keeppower%2018650%202800mAh%20(Black)%204.3V-Energy
Keeppower%2018650%202800mAh%20(Black)%204.3V-PowerLoadTime
Keeppower%2018650%202800mAh%20(Black)%204.3V-TripCurrent
Keeppower%2018650%202800mAh%20(Black)%204.3V-Charge
Test with 4.2 volt charging
It is possible and perfectly safe to use this battery with 4.2 volt, but it will have less capacity.
Keeppower%2018650%202800mAh%20(Black)-info
When only charging to 4.2 volt the battery looses about 200mAh in capacity.
Keeppower%2018650%202800mAh%20(Black)-Capacity
Keeppower%2018650%202800mAh%20(Black)-CapacityTimeHours
Keeppower%2018650%202800mAh%20(Black)-Energy
Keeppower%2018650%202800mAh%20(Black)-PowerLoadTime
Keeppower%2018650%202800mAh%20(Black)-TripCurrent
Keeppower%2018650%202800mAh%20(Black)-Charge
Conclusion
That battery uses a good cell and does what is supposed to do, this makes it a very good battery.
But the requirement for a special charger to get the full benefit of the battery, does reduce the usefulness of it. Using it with a 4.2 volt charger negates any benefit of the higher voltage and capacity.
Notes and links
Keeppower is a OEM manufacturer, i.e. many of the batteries they produce is sold with other names on them.
The batteries was supplied by Keeppower for review.
Edited by: sb56637 on 08/26/2014 - 17:46
Chicago X
Chicago X's picture
Last seen: 8 years 5 months ago
Excellent and thorough review, as usual.
Are there any non-hobby chargers of which you're aware that can muster the 4.35V required for max capacity ?
Thanks again for the review.
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
HKJ
HKJ's picture
I got this one some time ago.
Chicago X
Chicago X's picture
Thanks very much - I had completely forgotten about CP.
CheapThrills
CheapThrills's picture
Last seen: 1 week 5 days ago
Just used that great battery comparator on Your site, HKJ.
Realized, that these 18650ICR cells would be a very good replacement for my current favorites, the Xtars.
These seem to have also a “steep knee” in discharge graph, yet they can hold it a bit higher and a bit longer.
