I have 3 virtually brand new lights for sale. All are in mint condition (no scratches or issues) and were hardly used. Includes original packaging and included accessories.
Price includes shipping CONUS by USPS priority. Add $5 for registered mail.
Features listed are copy/pasted from Manufacturer specs.
First post "I’ll take it" has priority.
Paypal to hrubin01@gmail.com
Sunwayman V60C……………………$145 $135 $125 $115
SOLD per PM
Features
CREE XM-L T6 LED, with a lifetime of 50,000 hours;
● Digital Sensor Magnetic Control system - slightly twist the Rotator Ring from left to right to select your desired mode ranging from 5 to 728 lumens, super-low standby mode, or a strobe function;Hidden SOS Mode: when the light is at Strobe mode, twist the rotator ring to the Max output and back to the strobe within 2 seconds, the SOS mode is activated; twist the ring away from the SOS mode and stay for more than 2 seconds, the Strobe Mode is resumed and SOS is hidden.
Max Output: 728 Lumens (2hrs)
Min Output: 5 Lumen (150hrs)
Strobe: 728 Lumens
SOS
● Constant current circuit, constant output
● Effective range of 395 meters
● Uses 3 x 18650 batteries (V60C charging base can be applied to charge the batteries); or 6 x CR123A primary batteries; or 6 x 16340 rechargeable batteries, but V60C charging base must NOT be applied to the 16340!
● Working voltage: 5.5~25.2V
● High quality reflector maintains great throw distance and spread with an ideal beam pattern
● Dimension: 165mm (length) x 57mm (head diameter) x 45mm (body diameter)
● Weight: 354.6g(battery excluded)
● Aerospace-grade aluminum alloy
● Military Specification Type III- hard anodized body
● Waterproof, in accordance with IPX-8 standard
● Ultra-clear tempered glass lens resists scratches and impacts
● Tail stand capable- can be used as a candle
● Included Accessories: lanyard, O-ring, holster
Sunwayman M20C………………...$65 $60 $55 $50 Withdrawn
Features
● CREE R5 LED, with a lifetime of 50,000 hours
● Three modes constant output and one strobe mode (below is the output and runtime of using one single 2600mAH 18650 battery)
Three modes constant output:280Lumens (1.5 hrs) →50 Lumens(25hrs)→13Lumens(100hrs)
Strobe mode:280Lumens
● Digital Sensor Magnetic Control system, slightly twist the Rotator Ring to select from different modes
● Digitally regulated output - maintains constant brightness
● Effective range of 180 meters
● Compatible with both 2*CR123A(16340)batteries and one single 18650 battery
● Working voltage:2.5~10V
● Reflector of good quality maintains both great throw distance and spread, perfect beam pattern
● Dimension:133 mm (length)* 32mm(head diameter)*25.4mm(body diameter)
● Weight:120g(battery excluded)
● Military Specification Type III hard anodized
● Waterproof accords with IPX-8 standard
● Ultra-clear toughened glass lens resists scratches and impacts
● Tactical forward clickie switch for momentary on
● Tail stand and can be used as a candle
● Accessories: lanyard, O-ring, rubber cap, clip,tactical ring
Jetbeam BC40………………………$60
SOLD per PM
Features
• Premium Cree XM-L LED
• Powered by 4*CR123 or 2*18650 batteries
• Aero grade aluminium alloy construction
• High performance reflector-based optic system
• Fully regulated advanced power management
• Reverse polarity protection circuit
• 2 modes of output
• AR coated scratch-resistant mineral glass lens
• Type III hard-anodized finish for corrosion and scratch resistance
• IPX-8 Waterproof (submersible up to 2 meters)
• Impact resistant to 1.5 meters
Specifications and Performance
• LED: CREE XM-L
• Maximum output: 830 lumens
• Maximum runtime: 11 hours
• Battery: 4*CR123 or 2*18650
• Reflector: Precision aluminium reflector
• Dimensions: Head Diameter 48mm, Tube Diameter 25.4mm, Total Length 223mm
• Weight: 227g (without battery)
