As requested, 3 XM-L Driver/Emitter module DIY
469 posts / 0 new
scaru
scaru's picture
Last seen: 5 years 1 month ago
Any recommendations for a host?
PilotPTK
Last seen: 7 years 12 months ago
JonnyC wrote:
I have the same question as mattthemuppet, but want to say that those prices are very reasonable!  You were right, no sticker shock for me!
Glad to hear it.  I always try to use ESD Safe stickers.
PPtk
I am currently extremely busy with work. Please do not expect a response from me quickly. I will be dropping in as time permits, but the amount of time I can dedicate to responding to topics and PMs is very limited.
PilotPTK
mattthemuppet wrote:
Pilot, could you go into the programming aspect a little more please? Do you need a PIC tool or similar doohickey to flash new settings? Would reprogramming require disassembly of the light?
Programming the PIC will require some sort of PIC Programmer - there are very reasonable ones available directly from Microchip (PICKIT 3) that retail for about 40 bucks.  There are also some open-source serial programmers available on ebay or the like for 10ish bucks that are slow, but work fine.
A chip-clip will not be required as the programming pins are broken out to pads on the circuit board (you couldn't chip-clip the QFN anyway).  Personally, I use a 5 pin female header with pogo-pins stuck in the holes to touch the programming pins, but there are lots of ways to do it.
programming pins
Whether you'll have to disassemble the light depends on your enclosure/host.  The optic doesn't have to be removed if you can get to the circuit board edge with pogo pins.
Additionally, I usually write code for PICs in HITECH C, but for this product, I'm going to write the code in MikroC Pro (www.mikroe.com) because it's very simple to use and the compiler is free for code under a certain compiled size.  I own a full license of MikroC, so I can release compiled hex files commercially.  I'm going to try and keep the firmware under that limit so that anyone can use a very friendly tool to change the code.  I may also cross-write the code in MikroBASIC Pro for those who aren't comfortable with C programming.  Basic is very natural language and pretty much anyone would then be able to make changes.
PPtk
benckie
benckie's picture
Last seen: 8 years 9 months ago
I like 1A tint, would these be suitable for D & C mag's with flat heat sinks to mount the unit.
rschultz101
Last seen: 7 years 4 months ago
basic sounds good to me.  no clue on programming,...
for housing, working on it:
1x 3up
2x 3up
 going to be  DIY KIT , including, cable, remote switch, and mount.
the 1x3up going to be round, for the 2x3up, thinking square .
preferable, the housing, should only need 1 screwdriver /hex to assemble.
Sirius9
Sirius9's picture
Last seen: 2 days 18 hours ago
excellent job, I especially like those "easy to access" programming pads, very convenient, this can easily be made in 5-pin connector Smile
although over my pay grade (fully assembled module is about 1/3 of average monthly salary over here) I think that the prices are very fair, I look forward to  see how will a professionally soldered module look like (clean and neat job) :d
JonnyC
JonnyC's picture
Last seen: 9 months 5 days ago
I'm wondering the same.  Normally I try to find a driver/emitter for a specific host, but this time I will find a host just so I can run one of these Smile
PilotPTK
Not yet, I've actually ordered a number of hosts that I think might be a good fit - Most of them, unfortunately, are shipping from china and as such won't be here for a month or so..
Once I have them, I'll test fit the module into them and let everyone know the results.
PPtk
scaru
scaru's picture
Anyone know would this fit in a d maglite? Maybe if the head was drilled out.
fishinfool
fishinfool's picture
Last seen: 2 years 5 months ago
Aloha and welcome to BLF rschultz101!
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
NightCrawl
Last seen: 5 years 10 months ago
This module: 35mm
ID of Mag: 48mm
scaru
scaru's picture
NightCrawl wrote:
This module: 35mm
ID of Mag: 48mm
Oh, I must have missed that. Thanks. Smile
NightCrawl
No prob. Smile
At first I thought I should add some phrases concerning a good heatsink, maybe modding the upper part of the host and so on.. then I noticed that the posters name was scaru. Big Smile
viktori
viktori's picture
Last seen: 5 years 4 months ago
What is the height of the module with and without the optics?
If anyone wonders... inside diameter of the Mag D body, where the head screws on is 34mm, and outside diameter is 44mm.
Viktor
This is my flashlight collection.
scaru
scaru's picture
NightCrawl wrote:
No prob. Smile
Not quite sure I'm deserving of that compliment. :8)
raccoon city
raccoon city's picture
Last seen: 7 min ago
It's good to have you here, rschultz101!
benckie
benckie's picture
Viktor
Maglite D flat heat sink top row second from the left
http://www.britelumens.com
Thats what i was thinking, just tap and die the center hole
PilotPTK
Viktor
The full mechanical specifications can be found in the original post, but the height is 15.4mm.  I always assume a little slop due to manufacturing tolerances and leave 16mm of clearance.
PPtk
Edit: Without optics, the tallest thing on the circuit board is the Inductor.  Without optic the total height is 0.4mm (circuit board) + 5mm (Inductor) = 5.4mm.
The XM-L emitters are 3.02mm tall, so the height of the emitters is 0.4mm + 3.02mm = 3.42mm
Those numbers are a LITTLE low since there is some solder between the inductor/emitters and the circuit board, but at most the solder accounts for an additional 0.127mm (5 mil solder stencil).
PilotPTK
Almost There!
BareBoards
PPtk
scaru
scaru's picture
viktori
viktori's picture
Oh, wow. Man, you are such a tease. Smile
PilotPTK
That wasn't a tease..  This is a tease Smile
CloseBare
CloseBare2
Hehe..
PPtk
NightCrawl
PilotPTK wrote:
Hehe..
PPtk
I can actually SEE the dirty smile on your face right now!
PilotPTK
NightCrawl wrote:
PilotPTK wrote:
Hehe..
PPtk
Haha, That's great Smile  Look really closely into the 24 karat gold pads and you're probably right, I'm sure I'm reflected in one of them Smile
PPtk
PilotPTK
For those who are intending on purchasing a DIY Kit, here is the assembly drawing - shows which part goes where.  All of this information is on the Silk-Screen of the board, but I find it much easier to build when I can look at a reference (and possibly even make notes on it).
Assembly Pic\
PDF Copy
PPtk
Foy
Foy's picture
Last seen: 6 years 9 months ago
Pilot:
I'm in for this one: Cool white U2 Flux 1C Tint, fully assembled module. Can't wait to review this bad boy.
Just tell me where to send the Paypal and when.
Foy
No referral links and nothing embedded . . . ever.
                      &nbsp
PilotPTK
Foy wrote:
Pilot:
Foy
I thought you were NeutraWhiteLovingFoy ? ?
texaspyro
Last seen: 2 years 6 months ago
Gold plating for solder pads can be a bad thing!  Gold tends to form intermetallic compounds with lead/tin/aluminum (google "purple plague" for a well known example).  These can be brittle and poorly conductive.   Components have been known to fall of circuit boards...
NightCrawl
PilotPTK wrote:
Foy wrote:
Pilot:
Foy
He'll buy both versions anyway, we know the Foy, dont we? Wink
mattthemuppet
Last seen: 8 months 1 week ago
looking great Pilot, can't wait to see these in action.
About the programming - can the controller chips be supplied programmed off the board for self-assemblers or can they only be programmed after assembly using the pads on the board?
