has anyone tried using protected 18650 on the version 5 of this charger ?
fasttech says max battery length for version 5 is 65mm (Length of unprotected batts)
I plan to use it mostly as a battery back up for my phone.
I bought the wrong one which is the version 5.0 that can only accept an unprotected battery (max battery length is 65mm)
will this harm my unprotected battery when used on its full power to charge a phone ?
Planning to get either Panasonic , Sanyo or samsung unprotected battery. Just for this charger.
understand that this charger has a feature “Over-charge (4.2V) and over-discharge (2.9V)”
based on lots of reading discharging below 2.9V is bad for an unprotected batterry. (I’m not sure if the forum is old or new, cant seem to get to that page again.)
That is simply not correct, depending on the actual LiIon battery the minimum voltage during discharge is 2.5, 2.75 or 3.0 volt, Panasonic 2900/3100/3400mAh are all the 2.5 volt types.
How do you / where do you get this information? - saw it on fasttech battery description, i hope they are accurate
so those panasonic would be safe with this charger ?
@buwuve
i think you got the version 3 which supports protected 18650 (Support max battery length 68.8 mm)
@GottaZoom
I think you got the version 5 which only supports unprotected 18650 (Support max battery length 65.0 mm)
Panasonic datasheet, you can often find a (shortform) datasheet for LiIon batteries and it will list the key parameters.
The full datasheet is much more interesting, but is very hard to find on Panasonic cell (I have only seen it for one cell), it list not only the standard parameters, but also maximum parameters and safety tests (Can be stuff like short circuit and over charging).
P.S.: If anybody has some full Panasonic datasheet (i.e. more than 2-3 pages) and want to share them with me I would be grateful.
Hi guys. Just received 2 of the version 5 ML-102 and decided to modify one to fit a 70mm cell These ones.
All seems ok, they fit great, although after charging for around 2 hours so far, the cell has heated up quite a bit.
I’m no expert, but how much heat is too much?
It looks like my multimeter is broke, it’s been a while since it was last used. I’ll pick a new one up tomorrow.
I’ve got the charged plugged into a wall plug with a USB outlet, 5v 1a.
Panic over, I think. Picked up a new multimeter and all 4 cells are between 4.19 and 4.21 volts.
I run all 4 cells in a Skyray King, so I’ll be keeping an eye on them.
If you open the casing up, you’ll see that the negative terminal can be pushed back a little. I wrapped a little insulating tape around the legs of the LED then i Dremelled the case so that the 2 parts could fit back together. I think I crimped the negative terminal a little too.
It’s a little hard to explain, but so easy to do.
