Project Cancelled
Do you think a Nichia 219 can take 2800ma?
Nichia on a copper center.
XP-G star "Hacked" (and I do mean hacked) out ugly. Copper rod in the center, copper round under the star. Arctic Alumina Adhesive between the aluminum star and copper round. When I put the AA on, I made sure it squeezed up around the copper center, to isolate it from the outer terminal strips, since the job was so bad looking and since it looked like it could short. I just wiped off the excess and let it harden. Seemed to work out well. No shorts.
I don't believe it! It works! I ran solder on the two outside strips, with my iron, but in order to get the copper center hot, I had to resort to my torch, heating down low, under the star and copper plate, on the bottom of the rod. I put solder on it and sat the Nichia on. Hit it for a second on the rod again, with the torch and the emitter sucked right down. Then I started blowing on it really quick, since I knew it would be hotter than it should be, but it looks (and works) fine!
Watch the video to see it working!
I got the reflector into the head, so I could mark "center" on the heatsink. Got the heatsink drilled and put the copper rod/star assembly on it and screwed it all down.
Here's a couple photos and a video of it.
I left the excess, just to show how well it squeezed out, when I screwed it down.
Here's the video.
Project Cencelled
