I don't know anything about software scopes but it should work.
The princple is that all diodes are light sensitive, even ones that are meant to emit light.
As proof of concept I dug out a red 5 mm led from my junk box and shone a flashlight on it while it was connected it to my old Telequipment oscilloscope.
The trace isn't the shape I had expected but c'est la vie. The period is 90 microseconds and the amplitude is 90 mV. I leave it as an exercise to show that the frequency is a bit over 11 kHz
The software is intended to analyze captured sounds. My ultrafire c3 emits sound in every mode it is turend on. The lower the mode is the more it is audible. A good microphone is probably enough to pick even the tiny anomalies we don't usually hear. I understand that what i hear from the c3 is in the range of 1-5kHz. That might also be the pwm of the led driver.
I watched X-files yesterday evening so please be nice with me if this sounds too science fiction...
ScullytheytookmysisterFoy!
Where did i have misplaced my studio grade mic... ?!?
It isn't the sound emission but the PWM producing audio-frequency pulses - which is what soundcards read and write. The trick is getting it to a voltage that the card can understand or cope with. The forward voltage of most LEDs is in that range. You feed the driver output to the LED into the Mic input. Not a good idea for high-power drivers but XR-E drivers shouldn't fry the card.
At least that's how I've always understood how they work.
Best to use a well protected and very cheap sound card to try this.
Try moving the flashlight during a predetermined exposure on your camera. Then count the number of individual segments created for that particular timelength (exposure).
For instance if the exposure is 1/4 of a second and it yields 25 segments then the frequwency is 100 per second.
Just connect a light sensor to the input of your soundcard. In this case your light sensor happens to be a led. That's all.
The AC voltage needed by the soundcard is generated by the led alone. Leds can work either way: electricity-to-light and light-to-electricity.
Just shine the flashlight onto the led. As I mentioned in a previous post the led will generate an AV voltage in the neighborhood of 90 mV and 90 mV is absolutely the perfect voltage for a sound card.
Nothing will be fried. A piezo microphone puts out voltages in the same ballpark. Have you ever seen the output from a microphone fry anything?
Remember, you don't take your light apart! You just shine it on your light sensor. Clear?
I don't know much about any of this, but if you divide 1 second by 90 microseconds you get 11111.111... In other words there should be about 11,111 pulses per second, or 11Khz.
Thanks Angus. I always love DIY meters for something! Being able to hook them on a PC even is even better! I make my own using STP cat 6 cable i have laying around and grounded one side should be pretty okayish (will use only 1 twisted pair of the 4, many do very stupid things with those cables...). Anyway... any LED in particular that works better in this application or should i try a few then decide myself? :)
I took few measurements with soundcard oscilloscope program and small green diode as sensor. After reading results I finally understand pwm problems with led flashlights. PWM frequency is just one part of the problem, other one is small duty cycle percentage, which in combination with low PWM frequency is responsible for that nasty flickering feeling.
Few examples:
Dealextreme UltraFire P10 with XP-G R4 warm (no visible flickering)
Hz
Duty % approx.
Current
High
7819
65
1350 mA
Mid
7826
50
820 mA
Low
7826
20
290 mA
Strobe
5,1
50
Jaws light with AMC7135 AK-47 driver and xr-e q5 3-mode (no visible flickering)
Hz
Duty % approx.
Current
High
4514
80
990 mA
Mid
4528
30
300 mA
Low
4520
5
40 ma
Strobe
n/a
n/a
Dino Direct C8 with SG PCB (barely visible flickering on med. terrible on low)
Hz
Duty % approx.
Current
High
197,8
85
2700 mA
Mid
199
40
1210 mA
Low
200
5
120 mA
Strobe
9,9
50
Manafont Trustfire TR-3T6 3x18650 (barely visible flickering on med and slightly worse on low)
Hz
Duty % approx.
Current
High
n/a
n/a
1570 mA
Mid
122,9
40
700 mA
Low
147,5
10
180 mA
Strobe
7,9
50
Manafont SkyRay P10 with XP-G R5 with AMC7135 based driver (no visible flickering)
Hz
Duty % approx.
Current
High
n/a
n/a
1030 mA
Mid
123,7
50
510 mA
Low
123,7
25
250 mA
Strobe
7,5
50
KD 105C 8xAMC7135 driver powering 3x xp-g R5 in parallel (no visible flickering)
Hey guys, I'm looking to build this cable over the weekend but using solar cell that was removed from calculator. The highest voltage I measured was around 3v, would that be ok for this set up?
Also, I see the wiring diagram above but I don't think I have a mono jack so:
do I just simply wire the stereo cables together (matching the colors)?
