had to escape to the garage as the parents and kids were driving me spare. Instead of doing what I meant to do (continue building my milling attachment), I got distracted with my C20 pill.
Idea - 1) add some copper to the pill to make the bit under the LED (what’s that called?) thicker, as it looks barely 1mm thick as stock and 2) make a direct to copper sinkpad-pill bonanza megamod of the gods. Reality turned out a little different, but I’ll get to that in a bit. Raw materials
cutting out the blank
blank cut out (it’s about 1.8mm thick, so the pill will be almost 3x as thick) and in place
soldered in place with el trusty blow torch. First time doing this, but I’ve watched Old Lumens do it so many times I’m almost a pro
pill and star drilled for wires
All in place with the 12G wires that are going to pop riveted in place between star and pill
hmm, this didn’t go so well. Pressing the wires in pushed the star off centre, then I soldered the wires in place, but the star was off centre. Then I tried reheating the pill to centre the star. Then one of the wires fell out. Then things started smelling bad.
time for star no. 2
this time I decided that Nightcrawl’s idea might be a better one and drilled/ filed out the centre pad of a new star. Some dremel work got the two wires sort of rectangular. Star didn’t sit flat because pressing one of the wires distorted the bit that the star sits on. Bah. Oh well, hopefully the wires’ll do the job instead.
back side
paste in place
some no. 4 on the hob later and…
I put some paste underneath the star for good measure, can’t hurt. Star is fixed in place and there aren’t any shorts, so I’m guessing it worked.
I’ll wire it up and test it later, fingers crossed. Build might not get done for a little while, but I’ll try and get it done sometime next week.
