https://www.fasttech.com/products/1127402
I ordered two of these boost drivers and checked the current draws in various battery configurations.
Using 1 NiMH cell fresh off the charger it draws 2 amps. With a more depleted battery the current draw goes down to 1.7 amps, and it draws 1.0 amps from an almost empty cell.
So I thought it was an unregulated driver, drawing more current with higher voltage.
But if I use 2 fresh NiMH cells, the current draw is also 2 amps, just as with one fully charged cell. So it seems to be regulated to some extent.
The fasttech product page states the following:
Booster driver mode when input voltage is 1.5V or less
Linear regular (constant current) mode when voltage is between 1.8V and 3.6V
Rated at 500mA current output @ 1.5V input
Rated at 800mA current output @ 3.6V input
I don't understand the part about the boost driver mode. To my understanding, the driver has to be always in boost mode if the input voltage is under the Vf of the LED.
What do you think?
Comparing these values to this popular DX driver, it is obvious that the DX driver is regulated, trying to supply constant current to the LED:
http://dx.com/p/1-5v-4-2v-3w-cree-circuit-board-for-flashlights-16-7mm-5-6mm-25505
1xNiMH: 1.8A
2xNiMH: 1.3A
2xLithium AA: 1.1A
I think I still prefer the DX driver, but the FT one gives more juice at higher Voltages.
Edit: fixed typos
