No problem. We are here to help. :)
[quote=ohaya]
After reading through several threads, I'd been dreading trying to get the pill out of this X6, so I'm glad that I'll be able to get to the emitter without doing that :)!
[/quote]
That's one of the reasons why I suggested those two mods. There was no separate contact plate in my X6, so I managed to break the driver when drilling holes. It has now only one mode..
[quote=ohaya]
Ok, re. emitter: I'll probably go with an XM-Lx on Noctigon, and de-doming that. My "logic", such that it is, is to keep the SST-90 intact, as it sounds like I'd get much better results performance-wise with the de-domed XM-Lx anyway, so there doesn't seem to be much point to trying to de-dome the SST-90. Plus, to do the XM-Lx, it'll already be out of the light, since I'll be getting it new anyway. "Path of least resistance", you know :)
[/quote]
De-doming the SST-90 is very easy. Just take tweezers and twist & lift. Both Rikr and Dale did it and were happy with the results. You might still want to try it.. ;)
[quote=ohaya]
Going backwards a bit... So if the easiest path to better performance seems to be just replace the SST-90 with a de-domed emitter, which doesn't require removing the pill and finding a suitable driver which doesn't drop down after a minute, why was there so much discussion about doing that way-back-when? Was it because de-doming wasn't being done? Or, because there were no XM-L2s? Wouldn't even de-doming just a plain old XM-L, say, U2 have been good?
[/quote]
Many reasons.. Mainly, De-doming wasn't as popular than nowadays. Using a XM-L would have been ok, but the problem was that anything over 3A was too much for XM-L on an aluminum star. Now, as we are using copper stars without dielectric layer, 5-6A is not a problem any more.
Another reason was driver swap was to try boosting the overall output, not only throw..
[quote=ohaya]
Edit: I just removed the front part of the head and reflector, to take a look at where the emitter is. It seems like it's somewhat deep into the front, and might be a little awkward to remove/replace (and re-solder) the emitter/PCB like that? Also, does the white insulation disk just pop off if you pry it (via the holes)? I haven't tried it yet...
[/quote]
Are you sure you split the head from correct place? Not from bezel, but lower. See scaru's photo:
The insulation disk pops up easily, but the hole in it is too large for XM-Ls => you need to use another additional insulation disk.
