I was the “OP” in that thread also, but couldn’t remember how we ended up and didn’t go through the entire thread. I think that you are correct though :)…
Still charging batteries. One came off of a TF 1 bay charger about 3 hours ago at 4.22V, and is now 4.20V. Waiting to get more of them fully charged, running 5 different chargers simultaneously, including 1 battery on my Accucel 6, which is now at 1965 mAh and still going :)!
EDIT: One of the batteries came off the Accucel charging - 2043 mAH - 4.18V - 167 minutes. For some reason, when I charge batteries on my Accucel, they always terminate at slightly less than 4.20V. I’m waiting for a couple more to complete, then will run a discharge test.
So, so far:
- Battery1: Off TF 1 bay charger at 4.22V - currently (3+ hours) 4.20V
Battery2: Off Accucel charger at 4.18V - 2043 mAh charging
Gonna be a long night (may not complete the 12 batteries tonight :laughing:…
EDIT 2: I started a discharge test on Battery1. It’s already at 2364 mAh and 152+ minutes and still going on my Accucel!
What is “Li-lo mode”? I am using an Accucell 6, and it was set for LiPo (which is what Accucell calls the 3.7V batteries) and cutoff voltage 3.00V.
EDIT: Ahh - re-read the manual, and there’s “LiIo” mode, 3.6V. Is that what you mean? Also, if I set that, does it automatically change the cutoff voltage for the discharge, or do I need to change the cutoff voltage manually?
I don’t know about your Accucell, but my iCharger has a lower cut-off and reconfigurable minimum voltage that can be set. I think yours can do such a thing too. Yes, the “lilo’ mode it is.
You didn’t answer the other question: You’re thinking that these batteries might have more than 2420 mAh capacity (that’d be good, right?)? I’ll try that, but not tonight since it’s 02:45 now :).
Also, BTW, every battery I’ve taken off the chargers after termination has been 4.20V - 4.22V so far.
And, also, I want to do a test later that I did before with another set of battery pulls, run an XM-L2 DD with a clamp meter. The last batch I tried got 7.9 amps when I did that (just really, really briefly).
Seems like ok batteries?
The one thing I noted that I don’t like is that the wrappers seem kind of flimsy.
Yes, the cells could give a higher, true capacity than what you got in the LiLo mode.
Yeah, those cells are still excellent.
Usually, cells from packs are flimsily-wrapped because they are usually intended for industrial uses (like inside battery packs, etc.) so probably no need for more expensive thick wrappers and printing.
You know what Jim, experimenting with the cells, specially from OLD laptop packs, has become another hobby of mine aside from lights. Since I don’t do modding, having a hobby charger and acquiring old and new packs can be quite satisfying, it’s a continuing process and the suspense of the health (or shall I say its remaining life) of a cell harvested from an old pack can be quite intriguing, to say the least.
I don’t have the codes anymore but I remember at that time the date codes were a hot topic and some of my oldest cells are 2003 deep yellow Panasonic CGRs I think, I still have some of them today, some retaining as high as 80% of its nominal capacity, although there were some packs (Sanyo, Panansonic, LG and Samsung) that were only 60% and were discarded, most were given away to friends who wanted free back-up cells.
Checking the Toshiba site, their docs for the A35 laptop go back to 2003 … 10 years ago :)! That’s not saying these packs are that old, i.e., they may be aftermarket.
I realized that I don’t have a working triple at this point, so as a quick test, I hooked up 2 XM-L type emitters in parallel (one XM-L2 and an older XM-L emitter), and connected them to one of the fully-charged batteries.
I got 5.83 amps (clamp meter - current to the paralleled emitters), so I’m pretty sure that the red batteries from this are similar to some earlier red ones that I got from a Fujitsu pack, and would probably be able to get 7+ amps out of them.
I’m guessing it’s because these are packs are for older laptops (early to mid 2000s, depending on the model), so these packs have probably have been sitting on their shelves for awhile, and they probably are just selling off inventory that is not moving.
Their loss, our gain :)! Or, looking at it another way: We’re helping the environment by not having them toss these into a landfill somewhere, right?
EDIT: BTW, all the 12 have been charged now, and came off of the chargers at 4.21V - 4.22V, except the one I charged in the Accucel. As I said, batteries always comes off of that charger slightly low, so I threw it into my i4, which brought it up to 4.22V.
I haven’t run a 2nd discharge test yet.
EDIT 2: Started the 2nd discharge test - Accucel set to “LiIo” and cutoff set to 2900. I was worried about setting to 2800 :(…
EDIT 3: I picked a battery that was in the “middle” of the order I charged them in. It came off the charger originally at 4.22V and after a couple of hours (when I started the discharge test) was at 4.21V.
EDIT 4: 2nd discharge test finished - 156 minutes - 2427 - discharge was at 1 amp like the 1st discharge test, but with Accucel set to “LiIo” and custoff set to 2900.
It seems like the batteries are actually 2400 mAh batteries?
Capacity: 14.8V x 6450 mAh
Number of battery cells: 12
This is the description of the pack. So it’s a 4S, 3P configuration. Since it is a 6450mah pack, it would suggest a 2150mah cell.
If you are averaging 2400mah/cell, that figure is, IMO, too high for a 2150 cell. Maybe your charger is reading it too high?
