I take it that in the head is a plastic lens, and below that you see the domes of the superflux leds with their fairly large dies.
Could be wrong though. I wonder if the lights are current regulated, that would give them a really good runtime with a usable ammount of light. Good find, paint me interested!
Looking at the pictures, it appeared that the 16340 one had red leds, wheras the 18650 one showed bright white. I'm anxiously awaiting your thoughts on this.
Note to self. Pay more attention. Looks like it might need to be modded out of the envelope. 4 of those white LEDs from squeeze lights might fit the bill. Should run for a good percentage of forever with those. Maybe 4 Nichia GS LEDs will work.
It has. It is nicer than I expected for the money - it is on the neutral side of cool white. It also puts out over 100 lumens which was a nice surprise. I'm sure I've stuck it on the lightbox but I can't find the numbers anywhere.
One annoyance is the resistored switch - it goes high-low-off
It pulls around 1.6A on an IMR 16340, 870mA from a protected Trustfire. It prefers shorter cells.
Expect a review soon once I've finished trying to persuade La Migra that a student visa costing a hundred quid to apply for is taking the mickey for two weeks. Don't expect to win that one though.
Doesn't seem to be a resistored switch - just an odd driver. Which I've yet to see. The plastic optic is loose in the head but resolutely refuses to come out.
Here's the top end dismembered.
The out of focus metal washer sits on top of the switch - the rubber switch boot sits on top of that, then the black retaining ring holds it all together. The switch is just sitting on top of the hollow tube - not elegant and there can't be much room in behind the LEDs for heatsinking material.
I don't think they are Osrams - I've not got any good enough photos to show this, but it appears like the typical generic China LED with the bond wires heading to close to the centre.
This is a burned LED from a dollar light that turned out not to be able to cope with 10440s. This is what the LEDs most look like (Apart from the burnt bit), but I've been wrong before. Wish I could get the optic out to have a closer look.
