Doesn’t work that way, Gearbest limits this to one time use per account. You have to create multiple accounts to do multiple orders. Too much hassle, IMO. MyLED offered same item with unlimited order quantity for like 14c more before this.
easily won at auction for < $4 now, took quite a while for that drop though. Not sure if these newer 3 mode ones have the slightly larger lens that the first 3 mode ones had.
However, at a couple of bucks more, and a few extra mm, the Ultrafire AT-916 18650 based zoomie has a smoother and longer zoom range, takes the larger battery, and in the pocket, doesn’t really feel bigger or heavier, though it is measurably longer, but most of the body is not thicker, other than lens head.
Just worked for me as well, $2.26 shipped with GB code and the points from the charger deal. The code now shows as expired for me also, so perhaps those with issues have already used the code previously? Or perhaps it’s a browser compatibility issue? Despite all the world ending dire consequences warnings, I used IE and it worked just fine.
