I’ve got a CR123A battery on Discharge cycle. Starting voltage indicated 2.8v. I’m discharging at 300mA. Selecting DISPLAY and changing it to voltage display shows 3.30v. How is that possible that the voltage has risen? Or is that the discharging voltage?
It is definitely on DISCHARGE mode, I selected it specifically. Something is wrong with it though. Timer is not counting it’s just on 0:00, but the mAh count is going up. It’s up to 1826 now. Impossible for a CR123 battery. I’m not sure if this is a fault with an old cell or charging bug.
Just making one is easy. Making one that easily handles any 1-4 cells and shows the charging/discharge info for each cell isn't so easy.
Now I may have just shown how little I've used my hobby charger. It would have to be wired in parallel to handle any number of batteries between 1 to 4 cells, but will the hobby charger tell the capacity and internal resistance individually for each cell during a discharge test? If not, I'll be rewiring and adding plugs to a 4 port charger to more easily change from parallel for charging and to series for discharging with 1-4 cells.
Ok' I'm getting confused about the starting voltage now. I know I measured them about 2 weeks ago and they were at 3.05 or so. When I put it in the charger it initially showed 2.8 before I started selecting mode and current changes. It's a PANASONIC CR123A. The authenticity or quality I can not guarantee as it was purchased 10 years ago from an ebay seller. However the fact that it still holds some charge at all is pretty amazing even if it was a fake. I can run another test to see what happens again and record the actual figures. But otherwise the fact remains that the charge increased during a DISCHARGE cycle and the mah count was up around 1850~.
Deckhard I don't believe there is any danger in discharging an already low battery, even if that was what I was doing. It will just go flat.
if you use charge mode, the cr123 might charge if it is already 2.8V… then, it might stop when full or maybe you could remove it at 3.2V
also, with a usb jack and leads we can test our phone batteries, etc.
This is exactly the sort of thing gauss163 was just telling you not to do. Do not do that.
Also if you are imagining using leads to attach the USB port of anything (cellphone included) to a charge bay, stop right now. Check the manual and only do what it says.
that is a good idea,
but which one needs to be underwater,
the cr123, or the phone battery ???
it must be the 123 because the phone battery is 3.7V li-ion
Don’t put the battery underwater! He means that you have to be underwater while operating the charger. Use the bathtub. Just hold your breath and reach your hands out to work the controls.
You really do not want to submerge most Li battery chemistries. If you manage to cause containment to fail, the Li will react with the water. Applying water to a Li fire will generate heat and hydrogen which will intensify the fire/explosion.
