Hi pilotdog68,
Thanks for your interests and looking forward to your nice review
Hi pilotdog68,
I got the older X5, same dimensions, and it seems awkwardly long at 137-138 mm. There’s a lot of wasted space in the design, but you are paying to accommodate the tail switch. If it’s like the X6R, the X6R has a fairly high parasitic drain compared to other e-switch lights, as I recently measured. Of course you always have the tail clicky to cut power on these though, vs. an MH20 low drain, for example. Of course though the X5 is excellent quality overall for the money.
X6R: 0.560 mA drain, NC MH20: 0.027 mA (0.061 mA if switch light blinking is enabled), SWM C20C: 0.009 mA, Olight S15: 0.001 mA. Measured on a Fluke DMM straight off the tail.
How are you even measuring parasitic drain on an X6R? On the X5R, you must disconnect power (the tail switch) to turn off the light, and I remember the X6R being the same way. I don’t think it’s a factor really at all with the X5R
There is a way in the X6R UI to turn off the light via the e-switch. I was assuming the X5R would operate the same, but guess not if you experimented with all options. I can check on the X5 this evening, and confirm. The X6R - I know I did it several times, and it’s why I used the X6R to test. Y3’s and Convoy L4’s for example, can’t be turned off from the e-switch. Some dual switch lights can be turned off on the e-switch, some cannot. Forgot what it was click&hold, double-click, something like that.
I think I remember that now on the X6R, but the X5R is definitely different. The only way to do that is plug the USB in, then click the side button. Without the USB plugged in double-clicking or holding gets you to strobe and SOS. Unfortunately the X5R is not very friendly to modding like the X6R was, but it’s a very usable light in stock form.
April 1st April Fools’ Day, did you have fun today Today’s new arrival
1. $22.03 Ultrafire 2100LM 3 x CREE Powerful Flashlight
2. $13.17 Ultrafire XM - L2 Flashlight ( 900LM)
Woah, I…I don’t even. That thing is egregious.
If you would disassemble this light and provide photos to us, you might sell one!
April 6th
1. $32 XTAR SV2 Smart Battery Charger
( 2 Slots Li-ion Ni-MH / NiCd / 10440 / 14500 / 16340 / 18650 / 26650 / 32650 / AA / AAA / C / D )
nput voltage: AC 110-240V
Output voltage: DC 12V / 1A
Cut-off voltage: Li-ion 4.20 ± 0.05V, Ni-MH / NiCd 1.45 ± 0.1V
4-level charging current: 250 + / - 25mA, 500 + / - 50mA, 1000 + / - 80mA, 2000 + / - 120mA
Cut-off current: 250mA ( less than or equal to 60mA ), 500mA ( less than or equal to 60mA ), 1000mA ( less than or equal to 100mA ), 2000mA ( less than or equal to 120mA )
Trickle charge current: 100mA
Standby current: Less than or equal to 30mA
Auto-on voltage: 3.90 + / –0.15V
*2. $6.79 1200Lm CREE XML T6 Outdoor LED Headlamp*( it’s produced by Luckysun, but products and package don’t including the brand name )
DC Cable version
USB Cable version
Main Features:
Utilizes super bright CREE XM-L T6 LED, delivers max 1200LM output
Two ways of wearing manners, can be used as headlamp or bicycle light
High - low - strobe, large aluminum SMO reflector throws excellent beam
IP65 waterproof standard, you can ride with confidence even in bad weather
High efficiency heat sink around the case prevents from over heat
Both USB cable and DC cable are available
3. $33.26 Nitenumen NE01 XM - L2 1000Lm Flashlight
Wow, is the NE01 a clone of the NiteCore MH20 or is it a re-branded equal? Less than 1/2 the price, specs tweaked up slightly, identical size and features, slight differences in styling.
April 14th
1. $99.95 for Nitecore MH20GT 1000LM XPL HI V3 Flashlight ( estimated date of the stock is May 20th to May 30th)
2. Eagle Eye X5 XM - L2 Flashlight
$21.50 3C 5000-5500K version
$20.96 1A 6000-6500K version
3. $3.70 ZQ - 88 Cree Q5 800Lm Zoomable Handy LED Flashlight ( black and sliver )
4. $4.24 ZQ - 89 200Lm Flashlight
April 15th
1. $12.65 Mecarmy U18 - 34 3400mAh USB Rechargeable 18650 Li-ion Battery
Now you save the money to buy the battery charger
2. $17.52 for StarryLight DXM U2 850LM Flashlight ( 1A )
Handheld size dive light, easy to carry over and store
IPX-8 waterproof standard (underwater 50m), ideal for underwater adventure
Magnetic side swith, infinitely variable brightness
Aircraft aluminum body and toughened glass lens, very durable and strong
Wide range circuit, powered by 18650 or 26650 battery (not included)
Comes with a long lanyard and a hand strap for easy carrying
Suitable for diving, camping, hiking, fishing and other outdoor activities
3. $79.95 for Klarus XT11S 1100Lm XPL HI Tactical Flashlight
April 14th
April 21th
$11.95 Suaoki solar panel foldable LED lartern
Suaoki™ Portable Collapsible LED Light USB & Solar Rechargeable Lantern Water Resistant light weight Lantern Suitable for Traveling, Camping, Hiking, Fishing, Outside Garden Patio, Emergencies
Features:
1. Solar Charging: turbo charge via the micro USB port in 3.5 hours with full battery. Three individual solar panels support charging when in emergency outdoor conditions with no outlets or power source.
2. Versatile Lighting Source: you can choose one of three lighting modes: high, low or SOS blinking, perfect for outdoor activities like camping, hiking, fishing, or a light source for late-at-night porch readings.
3. Convenient to Carry: portable, foldable and durable, this lantern can be adjusted to any particular space to fit your current needs. Shorter than iPhone 6 plus, it can be folded down completely to take the least space in your backpack.
4. Thoughtful Details: Hidden hanging hook design allows you to place the light on outdoor occasions such as camping light for your tent.
5. Smart Protection Chip: protects your lantern from overcharging, over-discharging and over-circuit, guarantees safety in utilization
April 27th
DQG Hobi Plus Titanium Alloy Flashlight 2700-3500K ( 10180 )
DQG Hobi Plus Titanium Alloy Flashlight - NEUTRAL WHITE 4000-5000K ( 10180 )
DQG Hobi Plus Titanium Alloy Flashlight - COOL WHITE 6000-6500K ( 10180 )
$17.51 Convoy C8 XPL H1 U6 3A 993Lm LED Flashlight
$16.07 Convoy C8 XPL H1 V2 1A 993Lm LED Flashlight
3. $15.89 for JAXMAN E2 Flashlight
May 2nd
Hello Guys, will you like today’s New Arrival
1. Nitecore HC30W 1000Lm Cree XML2 U2 Headlamp ( in stock )
2. Sony US18650 VTC5 2600mAh 30A 3.7V 18650 Rechargeable Li-ion Battery
3. SHENYU Cree XPG Baseball flashlight
$12.12 240Lm 31CM AA version
$18.79 350Lm 41CM AA version
$23.51 350Lm 49CM AA version
$14.62 240Lm 36CM 18650 version
C’mon GB, –3.36$ offer???
Hi zeremefico, thanks for your feedback, we have fixed the price mistake, the regular price, also means Map price is $54.94
