( 2 Slots Li-ion Ni-MH / NiCd / 10440 / 14500 / 16340 / 18650 / 26650 / 32650 / AA / AAA / C / D )
nput voltage: AC 110-240V
Output voltage: DC 12V / 1A
Cut-off voltage: Li-ion 4.20 ± 0.05V, Ni-MH / NiCd 1.45 ± 0.1V
4-level charging current: 250 + / - 25mA, 500 + / - 50mA, 1000 + / - 80mA, 2000 + / - 120mA
Cut-off current: 250mA ( less than or equal to 60mA ), 500mA ( less than or equal to 60mA ), 1000mA ( less than or equal to 100mA ), 2000mA ( less than or equal to 120mA )
Trickle charge current: 100mA
Standby current: Less than or equal to 30mA
Auto-on voltage: 3.90 + / –0.15V
*2. $6.79 1200Lm CREE XML T6 Outdoor LED Headlamp*( it’s produced by Luckysun, but products and package don’t including the brand name ) DC Cable version USB Cable version
Main Features:
Utilizes super bright CREE XM-L T6 LED, delivers max 1200LM output
Two ways of wearing manners, can be used as headlamp or bicycle light
High - low - strobe, large aluminum SMO reflector throws excellent beam
IP65 waterproof standard, you can ride with confidence even in bad weather
High efficiency heat sink around the case prevents from over heat
Both USB cable and DC cable are available
Wow, is the NE01 a clone of the NiteCore MH20 or is it a re-branded equal? Less than 1/2 the price, specs tweaked up slightly, identical size and features, slight differences in styling.
Handheld size dive light, easy to carry over and store
IPX-8 waterproof standard (underwater 50m), ideal for underwater adventure
Magnetic side swith, infinitely variable brightness
Aircraft aluminum body and toughened glass lens, very durable and strong
Wide range circuit, powered by 18650 or 26650 battery (not included)
Comes with a long lanyard and a hand strap for easy carrying
Suitable for diving, camping, hiking, fishing and other outdoor activities
Suaoki™ Portable Collapsible LED Light USB & Solar Rechargeable Lantern Water Resistant light weight Lantern Suitable for Traveling, Camping, Hiking, Fishing, Outside Garden Patio, Emergencies
Features:
1. Solar Charging: turbo charge via the micro USB port in 3.5 hours with full battery. Three individual solar panels support charging when in emergency outdoor conditions with no outlets or power source.
2. Versatile Lighting Source: you can choose one of three lighting modes: high, low or SOS blinking, perfect for outdoor activities like camping, hiking, fishing, or a light source for late-at-night porch readings.
3. Convenient to Carry: portable, foldable and durable, this lantern can be adjusted to any particular space to fit your current needs. Shorter than iPhone 6 plus, it can be folded down completely to take the least space in your backpack.
4. Thoughtful Details: Hidden hanging hook design allows you to place the light on outdoor occasions such as camping light for your tent.
5. Smart Protection Chip: protects your lantern from overcharging, over-discharging and over-circuit, guarantees safety in utilization
2. Convoy BD06 XML2 U2 1A 900Lm Rechargeable Flashlight
$24.01 U2 1A 6500-7000K Version
$25.46 T6 4C 4300-4500K version
Patented direct charging switch: Charges battery without taking it out
Intelligent constant current driver: AMC7135 x 8
Integrated pill with efficient heat dissipation
CNC machined aircraft aluminum alloy construction with anti-scratch hard anodic oxidation finish
SMO reflector: Aircraft aluminum alloy with vacuum coating
Low voltage warning / charging indicator / memory function / reversed polarity protection / tail stand
Powered by 1pc 18650 or 26650 battery (not included)
3. Ok, this is a budget new arrival, UKing ZQ - X900 600Lm Zooming Flashlight ( three colors ), I like their shape and size, do you
LOL I have something like this, it shines at least 100 mter on a simple AA cell
I ordered th silver and golden one, 85 GB points used so had to pay $4,- only so a very nice price for some nice little gifts that are impressive for people who do not know about flashlights
Thanks!
Isn´t that UKing ZQ – X900 600Lm Zooming Flashlight exactly the same (slightliy different design) as the already known http://www.gearbest.com/led-flashlights/pp_172292.html ???
I have two of those and they are nice AA car or emergency lights for the price, although that´s definitely NOT a Cree LED inside.
K.
