gearbest
(gearbest)
May 9, 2017, 7:25am
426
Palm-sized body with chocolate structure surface offers firm grip
IMALENT DM21T warm / Cool CCT
1000Lm Cree XPL HI Palm-sized Searchlight
Intelligent thermal control module automatically adjusts brightness according to body temperature
http://www.gearbest.com/led-flashlights/pp_626560.html
1pc 18650 Li-ion ( 2600mAh ) battery is included
IPX-8 standard waterproof ( 2 meters submersible )
Coupon: DM21TDEAL
Coupon Price: 32.99$
gearbest
(gearbest)
May 18, 2017, 4:28am
427
Original Xiaomi Philips LED Ceiling Lamp, warm and cozy lighting,
Simple, Beautiful and Intelligent
App Control Dual Light Source Intelligent Dimming AC 100 - 240V
Xiaomi Philips LED Ceiling Light - Support WiFi
It is deigned as sporting white color in a circular shape.
In addition, a moonlight mode which gives the look of the moon when turned on is surprisingly comfortable.
● 5min Fast Installation ( II electric shock resistant )
● 82Ra: 64pcs LEDs of high CRI provides museum lighting effect
● IP60 Dustproof: protects it from dust, and could get rid of the pesky insects
● 2700K to 5700K, brightness range from 0.1Lm to 2000Lm
● 25000 Hours Lifetime: constructed by premium materials and specified processes
● Efficient Heat Dissipation: unibody aluminum plate maintains highly efficient cooling
http://www.gearbest.com/flush-ceiling-lights/pp_633589.html?wid=21
coupon—- MiPhilips
price —- 89.99
gearbest
(gearbest)
May 18, 2017, 11:47am
428
Original Xiaomi Transmitter for Philips LED Ceiling Lamp
1pc CR2450 550mA battery
Integrated temperature and humidity sensor
http://www.gearbest.com/led-accessories/pp_633590.html
coupon: TSLamp
coupon price: 16.99$
expired time: 2017.06.30
gearbest
(gearbest)
May 24, 2017, 2:32am
429
KLARUS G35 presents its new flashlight, the G30, which is sure to please fans of KLARUS flashlights.
The G35 carries an up-to-date CREE XHP35 HI D4 LED chip with a maximum output of 2000Lm.
Indeed, the G35 features both high brightness and compact size.
The design of the integrated tube and battery compartment lets the flashlight be handled much more easily.
Besides the unique dual-switch adds more convenience in use, which makes it your best EDC partner!
Klarus G35 CREE XHP35 HI D4 2000LM LED Flashlight
http://www.gearbest.com/led-flashlights/pp_635125.html
Coupon: 3afy74n
Coupon Price:$74.99
gearbest
(gearbest)
May 27, 2017, 12:11pm
430
MecArmy SGN5 - Multifunctional EDC Alarm Flashlight
Cree XP - G2 S4 560Lm USB Rechargeable Instant Alarm / Turbo / Strobe
CREE XP-G2 S4 LED, max 560Lm in such a tiny size
Instant alarm, strobe and turbo for emergencies
USB rechargeable, charges in just 1 hour on any USB port
Charging time: 1 hours ( charging current 5V 0.5A )
Using time: 42 hours
http://www.gearbest.com/led-flashlights/pp_636669.html
Coupon: MecSGN5
Coupon Price: 24.99$
gearbest
(gearbest)
June 8, 2017, 7:52am
431
NITECORE NU10, 160Lm White + Red Dual Light Source Multiple Color Options
http://www.gearbest.com/headlights/pp_605448.html
an ultra lightweight and compact solution for runners, campers and anyone needing hands-free lighting.
Equipped with dual light source and dual-switch UI, the NU10 gives out max 160Lm output and provides 3 brightness levels of white light and 2 special modes of red light to preserve night vision.
NU10 features 170 degree wide angle illumination and can be tilted 60 degree to cover your field of vision as needed.
The built-in 900mAh Li-ion battery, can withstand at least 500 recharge cycles, allows the NU10 to run up to 150 hours.
Black, white, yellow, green, blue and red 6 color options. There must be one color suits you best!
NOTE: This product will not be shipped to the United Kingdom.
Coupon —NU10GIFT
Coupon price —- 15.99 $
gearbest
(gearbest)
June 14, 2017, 4:01am
432
zanflare F2 LED Flashlight - 4500-5000K Cree XP-G3 IPX8 Water Resistant 4 Modes
Aerospace Grade Aluminum Body with Anti Scratching Type III Hard Anodization
http://www.gearbest.com/led-flashlights/pp_613216.html
Emitters: 1* Cree XP-G3
Mode: 4 (Low - Mid - High - Strobe)
Low: 15LM;
Medium: 50LM;
High: 200LM;
Strobe: 200LM
Mode Memory
Runtime:
High Mode: 0.63H
Mid Mode: 8H
Low Mode: 32H
Max: 30h
Luminous Flux: 200LM
Luminous Intensity: 2630 cd
Color Temperature: 6500-7000K/4500-5000K
Battery Type: 2* AA not Included
Coupon—F2DEAL
Coupon Price—- $12.99 (CW/ NW)
Please check from here:
http://www.gearbest.com/led-flashlights/pp_613216.html (CW/ NW)
gearbest
(gearbest)
June 16, 2017, 10:21am
433
NITECORE MH12GT
http://www.gearbest.com/led-flashlights/pp_641261.html
6500 - 7000K 1000LM USB Rechargeable Light
CREE XP - L HI V3 LED
1 x 3400mAh NL1834 18650 battery ( included )
or 2 x CR123A battery ( not included )
Waterproof in accordance to IPX-8 ( two meters submersible )
Output / runtime ( 1 x 18650 ):
high: 1000LM / 1.25h,
mid: 280LM / 6h,
low: 55LM / 28h,
ultralow: 1LM / 520h
Output / runtime ( 2 x CR123A ):
high: 1000LM / 1h,
mid: 280LM / 3.25h,
low: 55LM / 20h,
ultralow: 1LM / 300h
Seek More: http://www.gearbest.com/led-flashlights/pp_641261.html
gearbest
(gearbest)
June 16, 2017, 10:28am
434
NITECORE F2 Flexible Dual-slot Battery Charger for 14500 / 16340 / 18650
http://www.gearbest.com/chargers/pp_649367.html
The F2 flexible power bank is dual-slot, outdoor power bank battery charger.
This double duty charger can power 18650, RCR123, 26650, 14500 and other IMR / lithium-ion batteries using the micro-USB, USB 3.0 cable,
be able to charge cellphones, flashlight, headlamp and other USB devices as a power bank with batteries.
Lightweight and durable, this is the perfect charger for outdoor activities such as hiking, climbing, backpacking, etc.
Compatible with: Li-lithium-ion / IMR: 26650 / 18650 / 17670 / 18490 / 17500 / 17335 / 16340 / ( RCR123 ) / 14500 / 10440
gearbest
(gearbest)
July 8, 2017, 8:00am
435
LiitoKala 18650 Li-ion Rechargeable Battery
1. LiitoKala Lii - 22A
3.7V 220mAh for Flashlight
Long life expectancy, recharge times up to 500 times
http://www.gearbest.com/batteries/pp_663621.html
2. LittoKala Lii - 25A
3.6V 2500mAh for Electronic Cigarette
Head Type: Flat Top
Protected: No
http://www.gearbest.com/batteries/pp_663875.html
3. LiitoKala Lii - 29A
3.7V 2900mAh for Electronic Cigarette
http://www.gearbest.com/batteries/pp_663880.html
4. LiitoKala Lii - 30A
3.7V 3000mAh
http://www.gearbest.com/batteries/pp_663882.html
5. LiitoKala Lii - 32A
3.7V 3200mAh for LG MH1
http://www.gearbest.com/batteries/pp_663891.html
26650 Li-ion Rechargeable Battery
1. LiitoKala Lii - 50A
3.7V 50A for Flashlight
http://www.gearbest.com/batteries/pp_663615.html
maukka
(maukka)
July 8, 2017, 8:21am
436
Cool new Liitokalas. Too bad there’s no shipping to Finland.
gearbest
(gearbest)
July 11, 2017, 11:29am
437
Sorry, sorry for come some late and sorry for the shipping method :person_facepalming:
MILSPEC
(MILSPEC)
July 11, 2017, 11:36am
438
Dear Gearbest, thank you for making the new Liitokala cells available, I can even see new shipping options .
Are there any technical specs available for the new 18650 cells? Do you know what the discharge could be? Would it be safe to assume that a 500 cycle cell has high-discharge ratings?
thank you!
gearbest
(gearbest)
July 12, 2017, 10:12am
439
MILSPEC:
thank you!
Hi, Liitokala cells are restocked now with coupon in the thread: Gearbest Daily Deal Updated: March 16th 2021/ Baseus LED Flashlight $21.99 with the code: GBREAKER - #2776 by gearbest
Technical specs for LiitoKala Lii - 26A 18650:
Model: Lii-26A(For 2600JM)
Type: Li-Ion 18650
Nominal Capacity: 2600mah(2500-2600mah)
Nominal Voltage: 3.7V
Working Voltage: 2.75-4.2V
Limited Charge Voltage: 4.2V
Rechargeable Battery: Yes
Rechargeable Times: Up to 500 times
internal resistance: ≤50mΩ
I cannot give you an answer from my assumption;) I will ask for experts if they would like to make a honest test for the cell, expecting ~
Thank you for your advice ~
Kind regards,
Jona
start90a
(start90a)
July 12, 2017, 11:53am
440
From specs quoted 50mOhm of internal resistence has good discharge capacity. The question is how much high currents do you need ?
NikolaS
(NikolaS)
July 12, 2017, 2:35pm
441
So great that you have new Liitokala batteries, but shipping simply not available for the most of us.
Could you please consider Turkish post as a carrier, as other stores on Ali do……
That would be awesome if possible and I would order at least 20-30 batteries right away…
Speadge
(Speadge)
July 12, 2017, 11:50pm
442
NikolaS:
This! Hear this man! Turkish post as a carrier would open whole new area to do business with.
Speadge
(Speadge)
July 13, 2017, 12:08am
444
hIKARInoob:
Air Dogan
He, he
Well, if native serbian says that Turkey is welcome as a carrier then who are we to argue with that. My humble opinion is that this man should be listened!
gearbest
(gearbest)
July 13, 2017, 2:30am
445
Hi, Dear all, thank you for your feedback and nice advice to the effective shipping way.
We will confirm some policies of Turkish post, and then make final decision.
Hah~ thank you all, any comments will be highly appreciated to Gearbest, we are all ears, fighting :student:
