Gearbest New Arrival: March 22nd, Convoy H1 CREE 29.99$
Dear GB-Team,
is this Klarus the only new Arrival? I miss some other new torches like Lumintop ODF30, Imalent RT35 + RT70, all the new Niwalker`s, etc. etc. etc.
So many flashlights are disontinued but no new ones to compensate…
I hope GB will get a lot of the new stuff… :sunglasses:
Regards
Carsten
iSDT C4 Smart Battery Charger LCD for AA AAA Li-ion Battery
https://www.gearbest.com/chargers/pp_1628808.html
The iSDT C4 Smart Fast Battery Charger is designed for charging 6 slots of 3 kinds of various rechargeable batteries simultaneously.
3A per channel and max 8A output makes charging quickly.
Six charging and discharging modes to meet all your charging needs. With a 2.4 inch IPS LCD screen, you can know the charging situation easily.
Support USB output, you can charge your smartphone at the same time.
Fast charging: support 3A per channel and max 8A output, quick charging
Battery size: AAA, AA, 10440, 10500, 12500, 13500, 13650, 14500, 14650, 16650, 17650, 18650, 20650, 22650, 26650
JETBeam SSR50 LED Flashlight CREE XHP70.2 P2 1C 3650LM - US PLUG BLACK
https://www.gearbest.com/led-flashlights/pp_1592802.html
The JETBeam SSR50 LED Flashlight is an incredibly widespread and versatile multi-purpose flashlight.
Equipped with a high performance LED offering a maximum output of 3650 lumens and runtime of 113h, this light has 5
brightness levels and 2 special light modes to choose from.
Main Features:
• Using high-quality CREE XHP70.2 P2 1C LED Bead with max output of 3650LM, bright light and long lifespan
• 5 normal brightness levels: turbo - high - medium - low - eco
• Digitally regulated circuit and intelligent temperature control system to optimize the performance and maximize LED lifespan
• Workable with either polarity with reverse polarity protection
• LED Power indicator to make it convenient for you to know the battery situation
• Waterproof rating: IPX-8 ( 2 meters underwater ), suitable for various environment conditions
• Powered by 7.2V / 5000mAh Li-ion battery ( included )
ORCATORCH D611 Diving LED Flashlight CREE XHP70
https://www.gearbest.com/led-flashlights/pp_1548208.html?wid=1433363
The ORCATORCH D611 Diving LED Flashlight is a primary canister dive light specially designed for underwater adventures such as scuba diving and cave diving. The light head is connected by a cable to the battery canister containing two 26650 batteries, this allows you to fix the battery canister to your body so you just need to hold the small light head when using it.
Main Features:
• CREE XHP70 LED, max output of 2400 lumens and max beam distance of 251m
• Water pressure resistant construction, depth rated to underwater 150 meters
• Alloy aluminum reflector with the professional optical analysis provides a further beam distance
• Toughened glass lens with two-side coating with 99 percent lights transmission
• Uses 2 26650 Li-ion batteries ( included ), long runtime up to 22h
New Chargers updated:
1.IC99V3.1 Digital Smart Charger Compatible with Li-ion NiCd NiZn NiMh Batteries
Charging Cell Type: NiCd,Lithium,Ni-MH,Lithium Ion,LiFePO4,NiZn
Compatible:
AA,AAA,18650,26650,14500,16340,14650,17670,10440,18700,18350,18500,18490,
25500,13500,13450,16650,22650,17500,16340 (RCR123),CC,DELTA VNiMH,10340,
17650,10500,16450,26500,17355,12340,12500,
12650,14350,14430,16500,20700,21700,22500,20650,13650,18670
https://www.gearbest.com/chargers/pp_1828437.html?wid=1433363
2.ZEEPIN BT - C3100 Battery Charger - PURPLISH BLUE EU PLUG
- The charging current can be selected for 200mA, 300mA, 500mA, 700mA and 1000mA
( 1500mA and 2000mA can only be applied when only slot 1 or 4 is selected ). Default discharging current is 500mA
- Designed for AA ( LR6 ) and AAA ( LR3 ) NiCd, NiMH or 3.7V Li-ion rechargeable batteries in size type of
10440, 14500, 16340, 18500, 18650, 26650, 26500
- Operating temperature: 0 - 40 Deg.C
- Max charging capacity: up to 20000mAh
https://www.gearbest.com/chargers/pp_726771.html?wid=1433363
3.Multifunctional 2 Slot 2A Quick Charge Microcomputer Controlled Smart Battery Charger with LCD Display
Compatible: C,D,AA,AAA,18650,26650,14500,16340,10440,18350,RCR123,
18500,13500,13450,16650,22650,16340 (RCR123),10340,17650,10500,26500,16500,22500
https://www.gearbest.com/chargers/pp_1635769.html?wid=1433363
4.ZH440C 4 Slots LCD Display Intelligent Indicator Batterie Charger with PowerBank Function For Li-ion or Ni-MH Batery
Compatible: 18650,26650,14500,16340,14650,17670,18700,18350,18500,
13450,16650,22650,17500,16340 (RCR123),26500
Charging Cell Qty: 4
https://www.gearbest.com/chargers/pp_1435580.html?wid=1433363
New Arrival :
1.TANK007 UV - 31 365nm 5W UV Rechargeable Flashlight
https://www.gearbest.com/led-flashlights/pp_1081920.html?wid=1433363
Main Features
● It adopts top-level professional UV chip from Japan of precise wavelength and 20,000 hours lifespan
● Brand and model: Japan 365nm - 5W
● Power source: 1 x 18650 Li-ion battery
● Waterproof: IPX - 8
● Anti dropping height: 1.5m
● Voluntary purchase accessories: charger, TANK007 18650 Li-ion battery
2.NITECORE TM38 Lite CREE XHP35 HI D4 Long Shot Flashlight
https://www.gearbest.com/led-flashlights/pp_690331.html?wid=1433363
Main features
● Applies CREE HI XHP35 D4 LED with a 1400 meters long lighting distance
● Integrated multifunctional OLED display
● 5 brightness modes for different choices
● Innovative two-stage switch offers a user-friendly interface
● Moisture protection complies with IPX - 8 waterproof ( immersion up to 2 meters )
● Compatible with Li-ion / IMR 18650 batteries as well as the NBP68HD battery pack
New Arrival :
1.NEXTORCH MyStar 360 Degrees Rotate Focus USB Rechargeable Headlamp
https://www.gearbest.com/headlights/pp_1589539.html?wid=1433363
Lumens Range: 500-1000Lumens
Luminous Flux: 550Lm
Feature: Waterproof,Rechargeable,Headlamp
Power Source: USB,Battery,USB,Battery
Battery Quantity: 1 x 3000mAh polymer lithium ion battery
Battery Included or Not: Yes
Rechargeable: Yes
Waterproof Standard: IPX-4 Standard Water-resistant
2.Skilhunt H03R RC LED Headlamp Flashlight CREE XM - L2 U4 - BLACK 6000 - 6500K
https://www.gearbest.com/headlights/pp_1573079.html?wid=1433363
Main Features:
• Super bright CREE XM - L2 U4 LED, max 1200 LED lumens output and max 145m beam distance
• 8 output levels and 3 strobe, suitable for different environments
• Rugged indestructible aluminum body with anti-scratching type III hard anodization, 1m impact resistance
• Built-in magnetic charging system, fast charge and convenient
• Waterproof IPX8, suitable for rainy weathers
• Power supply: 1 x 18650 / 2 x CR123A / 2 x RCR123A ( not included )
New Arrival :
TANK007 TK737 Rechargeable Focusing Strong Flashlight
https://www.gearbest.com/led-flashlights/pp_1219885.html?wid=1433363
Ultra high performance Cree LED provides Shock-Proof dependable light
80,000 hour LED life
High power flashlight with zoom function
Could focus the light with twisting
Twist precisely
Five output levels available
Automatic memory function, remember last used setting will come on at same level as when turn off
Waterproof to IPX6 standard
The price for Tank flashlight is expensive.
I remember years ago their quality is same as Ultrafire, uranusFire and many other XXXXfire brands.
Their design still look like low end Ultrafire lights and they’re charging big dollars :zipper_mouth_face:
Thank you for your feedback, we have submitted these information to our related colleague. :wink:
May 11th 2018 update:
MHVAST TS50 XHP 50.2 LED High Power Flashlight
https://www.gearbest.com/led-flashlights/pp_1830727.html?wid=1433363
Features:
● High efficiency constant current circuit and constant current output
● Premium type III hard-anodized anti-abrasive finish
● Humanized side switch function, one button to open or close the flashlight
● Stainless steel frame, ergonomic handle with anti-roll design
● High performance aluminum peel orange reflector
● Ultra-clear glass lens tempered with a violet anti-reflective coating
Specifications:
● Emitter Type: XHP 50.2
● Material: aluminum alloy
● Battery: 3 x 18650 Li-ion battery ( not included )
● Lumen: 2920 Lumens
● Operating voltage: 8.4 - 12.6V DC
1.1800LM 7xT6 USB Rechargeable 18650 LED Headlight
https://www.gearbest.com/headlights/pp_1836402.html?wid=1433363
Main Emitters: XM-L T6
Emitters Quantity: 7
Luminous Flux: 1800lm
Color Temperature: 6000-6500k
Battery Included or Not: No
Beam Distance: 400-500m
Body Material: Aluminium Alloy
2.MHVAST H10 Cree XM - L2 U2 LED Head Lamp - BLACK 3000-3500K 26
https://www.gearbest.com/headlights/pp_1830735.html?wid=1433363
Features:
● CREE new XM - L2 U2 LED with a lifespan of up to 50,000 hours
● Maximum output 560 lumens
● Working Voltage: 2.7V - 6V DC
● High efficient constand current circuit and output-luminance
● Durable, custom-designed micro controller drive circuit
● Side switch and mode changing infinitely variable brightness side switch
● High performance aluminum OP reflector for far throw
● Compatible Battery: 1 x 18650 battery
● Waterproof: IPX-8 standard
Convoy C8+ XPL HI LED 1100LM Portable Flashlight - DESERT SAND
https://www.gearbest.com/led-flashlights/pp_1845626.html?wid=1433363
Main Features:
● Unique design
Deep diamond knurling, u-shape tail, it is non-slip, waterproof, and abrasion resistance.
● Eight lighting modes
0.1 percent brightness, 1 percent brightness, 10 percent brightness, 35 percent brightness, 100 percent brightness, strobe, biking and battery-check, so many brightness options are convenient for us.
● LED will give you stable and bright light, nonthermal radiation, safe and reliable
● Widely application
It is suitable for camping, fishing, hunting, hiking, searching, working
● Powered by 1 x 18650 rechargeable battery ( battery is not included )
● Light source: XPL HI beads
● Input: 4.2V
1.HKV Flashlight Distress Signal Emergency SOS Red Flash Warning Lamp
https://www.gearbest.com/led-flashlights/pp_1844217.html?wid=1433363
Lumens Range: 200-500Lumens
Color Temperature: 6000 - 6500K (Cool White), 640 - 780nm( Red )
Light Modes: Strobe,Red beacon
Mode: 3(Low - High - Strobe)
Zooming Function: Yes
Rechargeable: Yes
LED Lifespan: >10000
2.MHVAST TG20 USB LED Dual Mode Flashlight
https://www.gearbest.com/led-flashlights/pp_1830730.html?wid=1433363
Specifications:
● Emitter Type: XPL V6
● Mode: high, medium, low, ECO; strobe, SOS, beacon
● Battery Configurations: 1 x 18650 or 2 x CR123 Li-ion Battery ( not included )
● Lumens Range: 235M
● Waterproof: IPX 8
● Charge: micro USB charging
Features:
● Equipped with high efficiency smart constantly current driver.
● Free Change modes from tactical to memory.
● Hardened ultra-clear glass lens with an anti-reflective violet coating.
3.XM-L T6 LED Flashlight
https://www.gearbest.com/led-flashlights/pp_1836395.html?wid=1433363
Flashlight size: Mid size
Lumens Range: >3000 Lumens
Feature: Waterproof,Cool,Strong
Power Source: Battery,Battery
Battery Quantity: 4
1.Yeelight Pro Smart LED Eye-care Desk Lamp
https://www.gearbest.com/table-lamps/pp_1842996.html?wid=1433363
Specifications:
● Power: 15W
● Input Voltage: 100 - 240V
● Working Voltage: 12V, 1.5A
● Color Temperature: 4000K
● LED Quantity: 88pcs
● Luminous Flux: 650lm
● Adjust Angle: 60 degree up to 90 degree down
Main Features:
● A uniquely-crafted look with durable build that fits simply everywhere.
● Choose favorite color temperature and brightness level for studying, relaxing or sleeping.
●Energy-efficient LED lamp emits non-ghosting and non-flickering lighting for eye protection.
● The stand can be adjusted for better visibility.
2.Xiaomi FZ101 Portable Zoom Flashlight
https://www.gearbest.com/led-flashlights/pp_1846889.html?wid=1433363
Specifications:
● Model: FZ101
● Interface: USB Type-C
● Battery Capacity: 2600mAh
Main Features:
● Lightweight Mini Design:
With its mini size, it is portable for you to bring it outside. The body is made of premium aluminum alloy with strong and sturdy design.
● 672 Lumens Brightness:
The max brightness is 672 lumens, meeting your needs of night camping, running, observation or exploration perfectly.
● 2600mAh Large Capacity Battery:
Comes with a 2600mAh large capacity battery, bringing you a brightness endurance for 2375mins.
3.PHILIPS LED Desk Light Stand Table Lamp
https://www.gearbest.com/table-lamps/pp_1847296.html?wid=1433363
Main Features:
● Energy saving; built-in LED, as part of the system
● Energy efficient; energy saving, compared to traditional light sources
● Advanced LED light; adjustable light intensity with dimmer switch
● Bright cool white light; Philips LED desk light stand with suitable color temperature
● Philips LED desk light stand with minimize the light that is reflected from the surface
● Excellent heat dissipation; there is no risk of burns
Xiaomi included a pre-collimator? Nice!
Dear Agro,
There is not including a pre-collimator.
1.JETBeam BR10GT LED Rechargeable Bike Light
https://www.gearbest.com/led-flashlights/pp_1848493.html?wid=1433363
Main Features:
● Unique design, compatible with multiple platforms: bicycle, handheld, rail mount and many more
● Rechargeable by USB port with water-resistant rubber cover
● Maximum output of 1100 lumen reach out to 230 meters
● Digital stitch constant circuit control. Up to 14 hours of runtime
●Battery Included or Not: Yes
2.ZHISHUNJIA 3-Mode XM-L2 White Light Flashlight / IPX8 100m Diving Depth
https://www.gearbest.com/led-flashlights/pp_1847019.html?wid=1433363
Feature: Waterproof,Diving,Charging indicator,Adjustable brightness,Power Indicator,Side Switch
Photographing,EDC,Rescue,Search
Battery Quantity: built-in 5400 mAh lithium-ion battery
Rechargeable: Yes
3.Folomov CAMP D4 Flashlight Campact and Portable Outdoor Torch 1080 Lumens
https://www.gearbest.com/led-flashlights/pp_1847023.html?wid=1433363
Flashlight size: EDC
Emitters: Cree XP-L V6
Emitters Quantity: 1
Luminous Intensity: 1080 Lumens
Feature: Waterproof,Lightweight,Portable,Popular,Adjustable brightness,Water Resistant,Pocket Clip,Anti-Roll Rugged Design,Lanyard,Integrated Heat Dissipation Design,Strong
Mode: 4(High - Mid - Low - SOS)
Rechargeable: No
Waterproof Standard: IPX-8 Standard Waterproof
On the picture we can see that the light uses 2 lenses. In this rare setup we call the one closer to the LED a pre-collimator.
1.ROFIS R2 700LM Tail Magnetic USB Rechargeable Flashlight
https://www.gearbest.com/led-flashlights/pp_1853796.html?wid=1433363
Main Features:
● Adjustable angle head
Flashlight head and body can be adjusted from 0 - 90 degrees. It is very convenient and practical.
● Indicator reminder
It has charging indicator, power detection, low battery reminder, active temperature control circuit, etc.
● Five lighting modes
700lm in extreme light, lighting time ( 330lm after 3 minutes ), 300lm in highlight, 98 minutes in lighting, 90lm in mid light, and 253 minutes in lighting; low profile 5lm, lighting time 43 hours; moonlight 0.5lm, lighting time 125 hours.
● Uses a 14500 800mAh lithium-ion battery
● Compatible with alkaline AA batteries and Ni-MH AA batteries
● IPX 8 ( 2 meters underwater ) waterproof, 1.5 meters drop-proof
ROFIS R3 Multifunction Bright Flashlight
https://www.gearbest.com/led-flashlights/pp_1849552.html?wid=1433363
Main Features:
● Magnetic tail cap
The powerful magnetic tail cap can be attached to the metal object, combining with head rotation, which enriches its usage scenarios.
It can be used as a headlamp, flashlight and so on.
● Uses a 18650 3400mAh lithium-ion battery
