Jax Z1 Zoomable with SST-50
Have a Jax Z1 with a SST-50 light engine that was made by vestureofblood. You will need (2) 26650 cells, b/c the driver requires it. Honestly, selling it b/c I need the batteries for another light & don’t feel like ordering more. $115 shipped in the US
Everythng in great shape. Brand new never outside body & lens. Also comes O-Rings, extra rubber boot,
Brass Pill , 20mm MCPCB, & XM-L2 Centering Ring if you want to make another pill & maybe use a driver so you can go to 1 cell & remove the extension.
The factory pill has been replaced with a copper one. The SST-50 is de-domed and is a 5 amp driver. Its a 3 mode. L,M,H with memory. Seems to be able to run a good while b/c of the extra heat sink.
Nice bright flood & some good throw with the De-Domed emitter.
beam shot pics? i was thinking about building this same light, buying complete would be much easier
Ok, will do tonight. It’s only 4pm right now
thanks
Its still too light out so I took a couple in the bedroom. In about 3 hours should be dark enough to do beamshot outside.
These are with my Iphone beam pointing at corner of wall. Room is approx 14x14
Control
High
Low
