Anyone know about this? I know there is another thread on an Acebeam headlight a few months ago but that thread refers to a XHP50 light. Now its showing MT-G2.
Although the specs show it uses 1x18650, but I’ve read that single cell isn’t possible with MT-G2.
LED: Cree MT-G2 LED with a lifespan of 10+ years of run time
Maximum Brightness : 2000 lumens;
Weight:47g(not excluded battery)
Power:1*18650 Hight Drain battery (Do NOT use 2*CR123A or 2*RCR123A battery)
Rated range:3V ~ 4.2V
Length:108mm
Head diameter:24mm
Body diameter:21mm
Waterproof to IPX-8
Impact Resistant:2 Meters
Accessories:Opetator´s manual, Warranty card, Spare O-rings, Magnet replace O-ring, Clip
an MT-G2 will not run on 3-4.2 (but could be boosted but it would not be boosted for long) or contrast that to the prohibition to running two 18350’s and the rest falls in place.
I sent the inquiry to Acebeam (when I receive a reply I will post it here)
Inquiry to Acebeam:
“You show this headlamp is MTG2 is that correct? How does it run MTG2 on single cell 18650 battery 3V ~ 4.2V?
Acebeam could do it as well. But this is something that just works ALOT better with a 26650 light. First of all, a 26650 actually has enough capacity for the light to have a decent output for a respectable amount of time. And secondly, a 26650 light can better dissipate heat due to its size and bulk. On the other hand, the MT-G2 would still probably be a good idea at lower power with 1x18650 due to its better tint and floodier beam compared to other emitters.
