Just got a couple new 18650 lights, and I wonder if they have over discharge protection. Neither one lists it, and I've read reviews, but haven't found an answer.
One is a Solarforce P60 drop in: http://www.solarforceflashlight-sales.com/product_detail.php?t=RB&s=53&id=692
and the other is the Convoy M1 https://www.fasttech.com/products/1601/10002364/1212404
Is it just assumed that most modern lights have this protection? The M1 apparently won't fit my protected Panny NCR18650B cells,
so I got these: http://www.mtnelectronics.com/index.php?route=product/product&path=59_88&product_id=191 which are unprotected.
My charger is an XTAR VP2, so it's capable of charging them, and safe as far as overcharging, so my only concern with the unprotected cells if they over discharge.
There are two kinds of low voltage indication to look for — either power off, or some kind of blink or flicker ‘warning’
I assume neither one is there and use protected cells.
You can test for it with an unprotected cell that’s already at low charge — put it in for a few minutes and see if the light keeps draining it, check the voltage, try again, and if it’s getting down to the safe level assume there’s no protection in the circuit board.
Two of those, with a 1/4” magnet between them gives you 2.4v more or less
(put the magnet in one of those nylon spacer/fat washer things to keep it from slipping sidewise and shorting to the case)
drop into a 18650 flashlight.
You have to check with a voltmeter to see what you’re actually getting; you can run NiMH down without harming the cells, to see how low the voltage can go before the light quits lighting up.
I’ll test some of mine and post by editing this response.
(tell us what indication you have? does it blink, or step down, or actually go dark? And at what voltage, if — I dunno how much Li-ions sag at low voltage, will checking the battery at that point give a reasonable guess where the driver cutoff is set, anyone know?)
Also note —- inexpensive lights often have, um, some variations in the driver used. Anything that would help identify the actual driver (maybe a picture of it in the pill, at least) could help.
I know for example the ZeusRays have had a variety of different drivers in them, over time.
Ok, that's great info on how to test, I can do that.
Yes, itwould be great to have a list, I'm kind of surprised that modern lights leave out that info..... On your Acebeam, how do you know it has that feature?
I have no indication, yet, just got 'em, need to use unprotected cells in one, wanting to exercise caution with them. I know I can pull the cells and text voltage,
but with all the features on these lights, I would expect over discharge protection would be more common. The Solarforce drop in doesn't have those parts visible.
