Hi guys,
I am looking for a XHP35, 26mm, 2.5A driver to use with 4S 18650.
I found something like this one: http://www.kaidomain.com/product/details.S024004
Any better sugestions, maybe with cell protection?
Try contacting Richard at RMM. If he cant provide a good solution, he might be able to tell you who can.
http://budgetlightforum.com/user/8696
Would this work?
But also isn’t the XHP35 rated at max 1 amp?
with good cooling 2,5 to 3 A would be the max above the the brightness reduces regarding to my measures
2.5A should be just fine to get some serious lumen from it, and not bun it down.
ohaya 1 amp max is the producers recommendation, like for XP-G2 which i use with 4 amp current.
Oh, and this driver has low voltage protection only for 2, or 3 cells. I am planning four.
I just took apart my X7 for you. The driver is 25mm.
Thx FlashPilot.
Any time. Good luck with your light cannon. :bigsmile:
