Off time cap is the old way of timing long presses, it is inconsistent with temperature and I generally don’t even use long presses because of that.
OTSM uses a cap to keep the MCU powered for a few seconds after the light is turned off so it can run a timing and get precise timing of clicks so it is not effected by temperature or anything else.
It only currently works with Bistro HD from Flintrock that I know of. I have yet to try it myself actually, hardly built a light all last year and the few I did were all e-switch lights so I never had a need.
I am about to build some boost drivers that will be using it though and I am looking forward to it. I will be replacing my EDC first thing.
I’m still not grokking the distinction (btw, whut’s “OTSM” stand for?).
I thought even the cheapie drivers with 3-pin µCs used that small cap to keep the µC alive just that second or so to be able to “remember” long enough when switching modes, when the switch interrupts power when half-pressed.
At first I thought it was a distinction between on-time and off-time when saving modes, but goggling the acronyms didn’t turn up anything meaningful.
OTC, reads the voltage of the cap and assumes the time the light was off based on the voltage in the cap when the light is turned back on. Only needs a very small and cheap cap, 1uf in most cases.
OTSM, uses the MCU timer to count exactly how much time has passed by keeping the MCU alive. It needs a very large cap, ~47uf in the above example.
I was going to do something similar to prevent Possessed Trunk Syndrome (ie, trunk pops open at random from spurious signals or just ghosts in the machine), and was even thinking of reflashing a cheap driver (w/ zener mod) to do that.
The official fix is a 2-shot relay, but for one reason or another it “doesn’t fit” my car. So I figured it’d be simple to make my own, using a relay to keep the power-signal broken unless the first hit powers the driver (and enables the relay) and the second hit is just a pass-through to the trunk-release latch. Just needed a way to keep the µC alive the few seconds to recognise the second hit and quickly power the relay as soon as it senses voltage.
Thought it almost hysterical to use a flashlight’s driver to do that.
I was part of the team which developed the OTSM code and now I finally learn what this abbreviation stands for. We didn’t use this term at that time if I recall right. Thanks! :student:
The capacity in OTSM cap is sensitive to voltage and temperature like with OTC, but it’s irrelevant because the timing is precise.
Think of a cap as a bucket of water. Turning off the flashlight is like draining the bucket. OTC: When the flashlight is off you are draining water at a quick but unknown rate. When you turn the flashlight back on you try to find out how much water was drained by looking at how much is left in the bucket, but because you don’t know how much was in the bucket to begin with you can only estimate. OTSM: When the flashlight is off you are draining the bucket at a much slower rate, but more importantly you are also measuring exactly how much water is being drained. When you turn it back on this exact number is available to you.
OTC works well enough for single short off presses. People have been doing this a long time, it works pretty good. In the above example it’s like simply checking if there is any water left in the bucket at all. But if you are going to time both short and long off presses it can be difficult. Have a look at this thread, and check out the results in post #15:Off-Time Memory Dependent On Altitude? - Resolved!. Try to reliably measure 1.5 seconds long off time presses with that light and you’ll run into problems.
I have updated the license on these drivers in the OP.
Clarifying that these drivers are open source for personal use like always.
For commercial use though you must now contact me and get my permission before using these drivers in any from. After having the TA name attached to completely sub-standard and defective drivers this has become necessary in order to keep knock-offs from ruining the name / brand.
From now on any commissarial use of these drivers, designs, layout and particularly the name and brand must come exclusively through me. You must show me the complete design and parts list you plan to use before you start production.
I want to see these used in commercial lights but only if they are done properly and to spec.
I only made a few light specific drivers, most were more universal in nature. All the drivers I have made are in the OP minus the MT09R / MT03 and GT70 drivers (which are on my to do list).
So you might be looking for a driver lexel customized.
Yes, I actually have a prototype sitting on my desk now. A few minor things they still need to tweak but it seems to be working good.
It is a TA based driver with a custom charging circuit setup for a 500ma charge rate. All running on NarsilM of course so the firmware is far far superior. I HATE the S42 but I actually really like this new light, except for the LED’s but then they are CW in the prototype so that figures lol. I plan to swap them out at some point.
