That’s what a top bin xhp70.2 can do given enough power and cooling.
Ok, thanks to the generosity of some BLF members I was able to order some more xhp70.2’s to test along with some more centering rings.
First here is the output test of an xhp70.2 M4 4000K 80CRI emitter.
And compared to the P2 xhp70.2:
Like a lot of high CRI Cree LED’s it does better then you would expect. The Vf is much lower which makes the lumens/Watt almost equal between the LED’s and the output is better then expected as well.
At the lower power levels it is only slightly behind and at high power levels it is only around 8% behind vs the 14% you would expect.
Now the 80CRI version does appear max out sooner, which is expected due to the thicker phosphor layer.
Overall though, it is a great LED for the GT. The lower Vf means it will run in regulation for longer then the P2 version as well and the tint is great. You can notice the higher CRI in the beam. It is worth the minor losses IMHO.
Now I would not use this LED in an FET direct drive setup, it could easily pull way too much power and go way past peak output.
